June
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Benz @ North, David Hulse, littoraldrift, Windchill, knh555
1001 Registered Users
956,033 Dacron Main
156,472 Ananda's Refit
Topics3,945
Posts18,946
Members1,002
Most Online223
Dec 17th, 2019
Fuel tank replacement #18067
11/16/18 02:53 PM
11/16/18 02:53 PM
MD
U
usa1136 Offline OP
usa1136  Offline OP
U
MD
It looks like I need to replace my diesel tank. I would much prefer to install a small bladder or plastic tank, but understand that would be lighter and most likely not OD compliant. Is that correct?
If I were to epoxy lead equivalent in weight to the additional weight needed, in the area of the original tank, would that be allowed per OD rules? Same question if I decided to go with a smaller aluminum tank.
Thanks.
Re: Fuel tank replacement [Re: usa1136] #18068
11/16/18 03:00 PM
11/16/18 03:00 PM
The class measurer will comment on this, but have you considered retaining the old tank and putting the new bladder tank inside of it? You could cut open the top and take out the baffles / trim sharp edges and lay the bladder in the old tank. You could plumb the new hoses and the tank will be "protected" if you screw the cover back on the old tank with corner brackets. That way you would retain the weight, but rely on the bladder for holding fuel.
You'll lose the ability to have a float level sensor with the bladder tank.
Moderated by  LChristy
0 registered members (), 40 guests, and 0 spiders.
First cruise
Spinnaker Mast Track Needed
by pez. 06/08/23 05:55 PM
Zephyr V2.0 For Sale
by Breezin454. 06/06/23 03:08 PM
Sliding hatch channel source
by Breezin454. 06/04/23 08:31 PM
Replacement table legs
by Navy Dan. 06/04/23 06:12 PM
by Navy Dan. 06/02/23 05:52 PM
Dockline fairleads
by Patrick Stinson. 05/30/23 09:02 PM
Barber hauler
by Navy Dan. 05/29/23 07:13 PM
Head door
by Steve Buzbee. 05/23/23 05:49 PM
For Sale: 1982 (Hull 434) "ENCOUNTER"
by David Hulse. 05/19/23 09:42 AM
