March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,359 Dacron Main
162,678 Ananda's Refit
Front Tank not draining #18069
11/21/18 03:19 PM
11/21/18 03:19 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
My tank under the V-birth dosen't seem to be draining at all and i have tried cleaning it out so it does. Any tips as its holding water? Also anyone know what length and size the the waste tank pipe is I need to replace mine and it will save me nipping to the boat and back.
Thanks
Re: Front Tank not draining [Re: Pabs] #18070
11/23/18 08:01 PM
11/23/18 08:01 PM
Burton, Michigan
N
nathankt79 Offline
nathankt79  Offline
N
Burton, Michigan
I'm no expert. However, I would check the air vent to start. I'm new to the my J/30 as well...but air has to go in for water to run out. That should be pretty easy to check too.
Re: Front Tank not draining [Re: Pabs] #18071
11/26/18 12:33 PM
11/26/18 12:33 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
No its the tank that runs into the bilge
Re: Front Tank not draining [Re: Pabs] #18072
11/26/18 02:03 PM
11/26/18 02:03 PM
Burton, Michigan
N
nathankt79 Offline
nathankt79  Offline
N
Burton, Michigan
I guess I don't understand. I didn't know any tank ran into the bilge. Forgive my being green, but is the v-birth one potable water or septic waste (black water)?
Re: Front Tank not draining [Re: Pabs] #18073
11/27/18 05:23 PM
11/27/18 05:23 PM
Do you mean the forward bilge draining to the main bilge? If so, it was discussed in this old thread.
Re: Front Tank not draining [Re: Pabs] #18074
11/27/18 05:48 PM
11/27/18 05:48 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
yes thats it!! thanks
0 registered members (), 35 guests, and 1 spider.
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
