So my spin pole end decided to shear in two last wednesday while racing home on the downwind leg. 15 kts of wind with the heavy wind chute up and BANG, the pole goes shooting across the deck. Tied it back to the ring in a hurry and was still able to reach the finish first in our class but what the hell man? What's worse, we have a 2 7/8" pole for which I can't find a replacement other than through rig rite. Any suggestions?
Thanks, Josh
Re: Spinnaker Pole End
[Re: JBiermann]
#16394 07/21/1502:47 AM07/21/1502:47 AM
Sounds like the right time for a carbon pole with ends that don't weigh 10lbs each!
Our poles are tree trunks; even if you don't want to go carbon, it is probably worth ordering new light ends and getting an aluminum tube to fit. The aluminum tube is the cheap part.
[Re: JBiermann]
#16396 07/21/1511:08 AM07/21/1511:08 AM
