978,305 Dacron Main
163,315 Ananda's Refit
J29 main on a J30 #18141
02/17/19 01:50 AM
02/17/19 01:50 AM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
Hi,
Will a J29 sail fit a J30. https://www.facebook.com/groups/sai...ale_post_id=1476514409151559&sfns=mo
Seems a really good deal
Thanks
Paul
Re: J29 main on a J30 [Re: Pabs] #18142
02/17/19 09:23 AM
02/17/19 09:23 AM
The J/30 specifications for hoist between measurement bands P is 38' and max foot length to boom measurement band is 13 '. The J/29 uses the same spars as the J/30 but comes in both masthead and fractional configuration with different mast heights and boom lengths. Here are the J/29 specs. There are some differences so you should check. The J/29 measurement tag on the foot says 12.11 ft so it probably came from a masthead rig and would be short on the boom by about a foot and 9" too long on the hoist.
Re: J29 main on a J30 [Re: Pabs] #18144
02/19/19 12:23 AM
02/19/19 12:23 AM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
Okay thanks for the info. I thought it would be to good to be true
Thanks
Paul
