I am trying to figure out the most economical way (cost) to bring back lines to the cockpit i.e my Cunningham and outhaul. I have the deck organizers set up its just how to mount the blocks at the bottom of the mast. Does anyone have any pictures on how to do it?
Thanks
Re: Lines back to the cockpit
[Re: Pabs]
#18163 02/26/1912:35 PM02/26/1912:35 PM
I have that it was more for how the Cunningham and the Out haul go back from the base of the mast. I have come up with an Idea and will placed my order so will see if it works.
