Engine starting question
#18157
02/25/19 12:52 PM
02/25/19 12:52 PM
Posts: 7 Oceanside, CA, US
MikeM
Oceanside, CA, US
I have a '79 J30 with the original Yanmar engine.
I'm having a tough time starting it when it is cold. Once it runs, it's easy to start.
I just had it worked on because of this. He said the compression was a little low on one of the cylinders (a little above 280) and then one of the injectors needed to be rebuilt.
The bad injector was rebuilt and he said it was fixed. I went down there and had the same issue.
I called the shop back and they suggested maybe I'm starting it wrong. My boat is an hour away so I can't just go down there and try it out.
So, what is the proper way to use the panel on a cold start?
I have 2 pull knobs: The one on the left will pull and stay out, while the one on the right pulls out and will go back in when released. In the middle of those is the start button.
44
guests, and 14
