J/Fest New England
Aug 10-11, 2019
Sail Newport
Registration
June
jboatracer120, OliverJames, PatchofBlue, mikeinct, Skipper Kenny
872 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
772,812 Dacron Main
109,194 Ananda's Refit
Topics3,657
Posts17,998
Members872
Most Online165
Mar 24th, 2019
Weight and waterline #18180
03/21/19 08:30 AM
03/21/19 08:30 AM
Burton, Michigan
N
nathankt79 Offline OP
N
Burton, Michigan
Does anyone have a handle on how much weight (on or off) will move the waterline on a J/30 a given distance...For instance, something like 300lbs=1"?
Nate
Re: Weight and waterline [Re: nathankt79] #18183
03/23/19 06:17 PM
03/23/19 06:17 PM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
How good is your math? I don't think there is a simple straight line ratio for pounds to inches since the hull gets wider and longer as it sits deeper in the water. That said lets do some simple math. 1 cubic foot of water weighs 62.43 pound. At the water line the boat is about 25' long and 8 ft wide. Figure the area of an eclipse that is 25' X 8' wide. Multiply it by 1/12' (1"). You will then have a rough idea of cubic feet of 1" of water at the water line
If your boat is out of the water - measure how much longer and wider it is 1" higher than the water line, 2" higher than the water line,etc.
Multiply each of those calc by the wight of 1cubic ft of water. It won't be exact but it will get you in the ball park.
Re: Weight and waterline [Re: nathankt79] #18188
03/25/19 11:16 AM
03/25/19 11:16 AM
Burton, Michigan
N
N
Burton, Michigan
Thanks for the input. I can probably riddle that out. I was really hoping someone already figured out a chart or something, lol. I'm trying to figure out how much the weight savings of switching to lithium batteries would have on freeboard. I also read something that said if one can reduce weight forward and aft of the center 1/3 of the hull, she'll cut through waves a bit better without "slapping".
1 registered members (J/30), 24 guests, and 1 spider.
First cruise
HURRICANE HARVEY WIND SEED
1983 J30 NO BRAKES FOR SALE
by jboatracer120. 06/20/19 08:00 AM
Sail number colors
by usa1136. 06/12/19 11:21 AM
Mainsail weight minimum
by Rhapsody #348. 06/06/19 08:04 AM
1983 J30 Sailboat
by Rhapsody #348. 06/04/19 03:23 PM
Sold: Parting Out #62
by Mark. 05/31/19 01:42 PM
Hull #20 Gritz for sale
by Jeff Waters. 05/30/19 01:46 PM
Electrolysis on Prop (Significant)
by Russ Atkinson. 05/30/19 12:40 PM
