977,822 Dacron Main
163,185 Ananda's Refit
Electrolysis on Prop (Significant) #18224
05/16/19 03:52 PM
05/16/19 03:52 PM
New Orleans, LA, USA
David Erwin Offline OP
Our J/30 is showing signs of significant electrolysis on the Prop.
Our diver suggests a potential bad ground to engine.
We do not have any power in harbor since Hurricane Katrina.
Any ideas or recommendations?
Dave
Re: Electrolysis on Prop (Significant) [Re: David Erwin] #18225
05/16/19 05:56 PM
05/16/19 05:56 PM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
We have gone to using a magnesium sacrificial instead of zinc. We are in fresh water so not sure how long it would hold up in brackish water as magnesium is not recommended for salt water
Re: Electrolysis on Prop (Significant) [Re: Russ Atkinson] #18241
05/29/19 12:22 AM
05/29/19 12:22 AM
Russ, This was the magic. Typically we are in brackish water as such zinc is best. Since the flooding has started the river water is now flowing through the lake causing a fresh water environment. I found this document to be very useful:
http://j30.us/images/WhichAnodeMaterial.pdf
Re: Electrolysis on Prop (Significant) [Re: David Erwin] #18242
05/30/19 12:40 PM
05/30/19 12:40 PM
Rockwood, MI, USA
Rockwood, MI, USA
Glad it worked Dave. Check it often, mine barely makes it through a year in pure fresh water
