977,684 Dacron Main
163,120 Ananda's Refit
Running a new spin halyard w mast up #18272
07/11/19 01:03 PM
07/11/19 01:03 PM
Highland Park, NJ
Steve Buzbee Offline OP
Highland Park, NJ
Does anyone have any helpful hints to make dropping in a new halyard less of a pain?
Blue Meanie J/30 #485
Re: Running a new spin halyard w mast up [Re: Steve Buzbee] #18273
07/11/19 02:06 PM
07/11/19 02:06 PM
use a about 9 inches of bicycle chain with small line attached. turn sideways and push over top of sheave, then turn 90 degrees so chain drops. let gravity be your friend then someone can snag with a hook (bent coat hanger works fine) through the exit plate on the mast. Tie on to new halyard and pull it through. Best if you have a reaving splice at the end of the halyard to attach the chase line.
Re: Running a new spin halyard w mast up [Re: Steve Buzbee] #18277
07/16/19 04:58 PM
07/16/19 04:58 PM
Highland Park, NJ
Highland Park, NJ
Thanks Bill-that's what we did except we used a magnet to grab the bike chain!
0 registered members (), 48 guests, and 0 spiders.
