Topics3,917
Posts18,872
Members995
Most Online223 Dec 17th, 2019
Navtec turnbuckle pin
#18270
07/10/19 10:24 PM
07/10/19 10:24 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
Anybody happen to have a spare Navteq turnbuckle pin D320-12?
Re: Navtec turnbuckle pin
[Re: Rhapsody #348]
#18275
07/11/19 04:45 PM
07/11/19 04:45 PM
D. Bartley
Chicago, Il. USA
In a different thread, you said it's a D320-S12? Is that actually correct for the lower shroud pin (or upper for that matter). That's a 3/8 pin that is 6" long?
[Re: D. Bartley]
#18276
07/12/19 07:30 AM
07/12/19 07:30 AM
D. Bartley
Chicago, Il. USA
I found an old pin and measured it. You're correct, 3/8, 6'5" long. Thanks
37
guests, and 0
