Cousineddy, Captain Rick, Boat Boxer, Hunter 34, Mark Littlefield
913 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
837,236 Dacron Main
126,126 Ananda's Refit
Topics3,727
Posts18,259
Members913
Most Online223
Dec 17th, 2019
Weight and waterline #18180
03/21/19 08:30 AM
03/21/19 08:30 AM
Burton, Michigan
N
nathankt79 Offline OP
N
Burton, Michigan
Does anyone have a handle on how much weight (on or off) will move the waterline on a J/30 a given distance...For instance, something like 300lbs=1"?
Nate
Re: Weight and waterline [Re: nathankt79] #18183
03/23/19 06:17 PM
03/23/19 06:17 PM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
How good is your math? I don't think there is a simple straight line ratio for pounds to inches since the hull gets wider and longer as it sits deeper in the water. That said lets do some simple math. 1 cubic foot of water weighs 62.43 pound. At the water line the boat is about 25' long and 8 ft wide. Figure the area of an eclipse that is 25' X 8' wide. Multiply it by 1/12' (1"). You will then have a rough idea of cubic feet of 1" of water at the water line
If your boat is out of the water - measure how much longer and wider it is 1" higher than the water line, 2" higher than the water line,etc.
Multiply each of those calc by the wight of 1cubic ft of water. It won't be exact but it will get you in the ball park.
Re: Weight and waterline [Re: nathankt79] #18188
03/25/19 11:16 AM
03/25/19 11:16 AM
Burton, Michigan
N
N
Burton, Michigan
Thanks for the input. I can probably riddle that out. I was really hoping someone already figured out a chart or something, lol. I'm trying to figure out how much the weight savings of switching to lithium batteries would have on freeboard. I also read something that said if one can reduce weight forward and aft of the center 1/3 of the hull, she'll cut through waves a bit better without "slapping".
Re: Weight and waterline [Re: nathankt79] #18286
07/22/19 12:36 PM
07/22/19 12:36 PM
Melbourne, FL
J
Johnny Blizzard Offline
J
Melbourne, FL
nathankt79, Did you get your weight-to-freeboard question figured out?
Re: Weight and waterline [Re: nathankt79] #18296
08/17/19 02:27 PM
08/17/19 02:27 PM
Burton, Michigan
N
N
Burton, Michigan
No...I kinda gave up on that one.
0 registered members (), 23 guests, and 1 spider.
First cruise
New North Main - too long?
by Georges. 07/01/20 02:27 PM
How to re-bed hand rails?
by Russ Atkinson. 07/01/20 10:36 AM
Where Can a Guy Get a Sink Around Here!?
by Koesh. 06/21/20 12:52 AM
by Koesh. 06/21/20 12:45 AM
Mast Cap for Sale
by Brett Langolf. 06/20/20 10:41 AM
J30 trailer for rent? East coast
by Brett Langolf. 06/20/20 10:32 AM
Velocity Girl #278 for sale
by HHSA. 06/18/20 05:15 PM
Cabin Sole Rebuild, MaJic Carpet
by Switchback. 06/12/20 04:05 PM
Wet bulkhead
by Rhapsody #348. 06/10/20 08:52 PM
