Re: best replacement batteries?
[Re: nathankt79]
#18176
03/11/19 05:55 PM
03/11/19 05:55 PM
Posts: 146 Melbourne, FL, USA
Rob Van Name
Melbourne, FL, USA
I bought two Duracell AGM group 24 batteries from Batteries+ for about $198 each. The Optima yellow top batteries lasted about 8 years. Life on a trickle charger is good.
[Re: nathankt79]
#18179
03/14/19 08:24 PM
03/14/19 08:24 PM
Posts: 63 Westerly, RI
Chris623
Westerly, RI
My suggestion would be 2 AGM batteries, but at a minimum would stay away from batteries marketed as marine starting or even marine dual purpose as those batteries are really only needed with very large engines. (Ref: Pbase-MarineHowTo) One of the best IMO is Odyssey Battery which used to be available as Sears DieHard Platinum. Odyssey states a 3-10 year service life. As I am on year 13 on the battery I use most often, I'll be sure to eventually replace it with the same.
38
guests, and 1
spider. |
