Cousineddy, Captain Rick, Boat Boxer, Hunter 34, Mark Littlefield
913 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
836,973 Dacron Main
126,064 Ananda's Refit
Topics3,727
Posts18,259
Members913
Most Online223
Dec 17th, 2019
Page 4 of 4 1 2 3 4
Re: 3DL Sail on Jib Furler [Re: Rhapsody #348] #9379
04/19/10 09:37 PM
04/19/10 09:37 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
Will stop by to see them next week ... if my sales rep is not out racing somewhere.
Let me correct my use time estimate in the post up above 420 total sailing hours but say modified with 1/3 Spin ... so that makes the sail life to complete delamination with free flowing treads 280 hours
Last edited by Cap'n Vic; 04/20/10 11:31 AM. Reason: added correction re sail life
Re: Jib Furler [Re: dbows] #10397
10/21/10 10:32 PM
10/21/10 10:32 PM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
So ok ... this is an update to an 11-19-09 note in this thread:
I replaced my 155 3DL and its horrendus dacron UV cover with a 155 Kevlar medium weight with a sock. North does a trade in 25% off deal every once and a while and they got back the 2 year old shredded 3DL.
There was no way I was going to do a dacon UV cover on anything but a dacron sail as they stretch differently and destroy whatever shape the trailing edge of the sail has as well as the bottom 20 or so inches.
So they sent me a sock ... which I am happy with since it covers the sail but doesn't effect the sail. mastman pulls it up on the spin halyard while foredeck guy holds zipper and guides it around. There is a lacing to really tighten it in ... but probably not bother with that unless we have a storm coming. So OK I got the longest zipper in the marina.
Also after 27 years with a Harken roller which was originally on 327 then to 505 ... I am about to put on the Harken IV Series 1. and a new forestay built by Hall. I hope to get another 25 years out of it ... the Harken ...not the sock ... if that sock lasts a year I'll be surprised.
By the way Harken recommends a low Clew ... and I have to admit the sail looks pretty good at that height with a furler. I had always thought of a raised clew to be able to see around/under better ... but with a 155 I don't think anything is to be gained visually.
Re: Jib Furler [Re: Georges] #10398
10/22/10 09:14 AM
10/22/10 09:14 AM
Atlanta, GA, USA
whitedolphin Offline
Atlanta, GA, USA
One tip on the sock we use with the melges with our race sails - we "loose roll" the sail - basically unfurl it a bit just to the point where the sock can barely fit on. Two benefits:
1) less tension on the material, reducing the tendency to develop a "hook" in the luff
2) at least on ours, when to sock is full of sail (no slack material), it wont flap in the breeze.
We also "reverse roll" the sail every other week, although not so easy on a big J #1.
-dan
Re: Jib Furler [Re: dbows] #10761
12/11/10 12:44 AM
12/11/10 12:44 AM
Newport and Naples
Cap'n Vic Offline
Cap'n Vic  Offline
Newport and Naples
this is a follow up on one of my comments above that i would never put a dacron UV cover on a high tech sail again. The two fabrics just don't do well together ...
So the alternative is a sock. After a couple of months screwing around with this option I think we have the basics down so it doesn't seem like a hassle anymore.
I subject you guys to one more of my training videos: Zipping the Genny Sock.
Re: Jib Furler [Re: Georges] #18336
10/23/19 07:52 AM
10/23/19 07:52 AM
Belmont, MA
G
Georges Offline OP
Georges  Offline OP
G
Belmont, MA
Harken MKIV Unit 1 vs. Unit 0: Harken MKIV Unit 1 is mention a couple of type in the forum. But did did anyone went into into fitting a Unit 0 - just for the sake of less windage?
-- Georges
Re: Jib Furler [Re: dbows] #18386
01/04/20 04:53 PM
01/04/20 04:53 PM
Belmont, MA
G
Georges Offline OP
Georges  Offline OP
G
Belmont, MA
Hi David,
Rereading your detailed answer from a few years back.
Did you (need to) add the harken halyard deflector to prevent twists upstairs?
And if you did, did you have to change your OD #1 luff to work around it?
Cheers,
-- Georges
Page 4 of 4 1 2 3 4
0 registered members (), 29 guests, and 3 spiders.
First cruise
New North Main - too long?
by Georges. 07/01/20 02:27 PM
How to re-bed hand rails?
by Russ Atkinson. 07/01/20 10:36 AM
Where Can a Guy Get a Sink Around Here!?
by Koesh. 06/21/20 12:52 AM
by Koesh. 06/21/20 12:45 AM
Mast Cap for Sale
by Brett Langolf. 06/20/20 10:41 AM
J30 trailer for rent? East coast
by Brett Langolf. 06/20/20 10:32 AM
Velocity Girl #278 for sale
by HHSA. 06/18/20 05:15 PM
Cabin Sole Rebuild, MaJic Carpet
by Switchback. 06/12/20 04:05 PM
Wet bulkhead
by Rhapsody #348. 06/10/20 08:52 PM
