Gary Krogman, David Moffly, Matt Arnold, Damian Sarno, HarryJP1
902 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
825,465 Dacron Main
122,793 Ananda's Refit
Topics3,710
Posts18,176
Members902
Most Online223
Dec 17th, 2019
Second bilge hose? #18366
12/15/19 09:48 PM
12/15/19 09:48 PM
CT
#511 Offline OP
#511  Offline OP
CT
I've searched the forums and can't find mention of a second bilge hose. I have a second bilge hose on #511. But I'm not sure where it goes. I can't find the other end.
The center grey bilge hose drains into the aft bilge sump. I ran a snake about 5' aft before it stopped. This would be just under the steps.
I used a camera to inspect the engine pan sumps and don't see anything.
Any ideas?
Greg
IMG_20191215_172833962.jpg [234.55 KBytes] - (98 downloads)
Aft bilge, #511
Re: Second bilge hose? [Re: #511] #18368
12/16/19 12:15 PM
12/16/19 12:15 PM
Charlottetown, Prince Edward I...
forbes Offline
forbes  Offline
Sounds like a drain hose from the molded lip which holds the edge of the engine cover? I noticed mine had two small holes draining water into a void which eventually worked its way back to the bilge. My hull does not have as much fiberglass on the aft end of the bilge platform area like yours does (yours seems to be sealed on the aft end). I think my bilge is relatively open on as it heads aft under the floor. Perhaps they closed it up and added a drain pipe after they got into the 500's. Just a guess.
Re: Second bilge hose? [Re: #511] #18369
12/16/19 01:26 PM
12/16/19 01:26 PM
CT
#511 Offline OP
#511  Offline OP
CT
Ah, that could be it. My drain holes don't drain. Prob need to be cleaned.
Thanks.
Re: Second bilge hose? [Re: #511] #18373
12/17/19 12:34 PM
12/17/19 12:34 PM
If you have a 2nd hose, it may address the problem others had draining aft of the steps. See this old thread - Dewatering Aft Bilge - Need Advice
Re: Second bilge hose? [Re: #511] #18374
12/17/19 01:44 PM
12/17/19 01:44 PM
CT
#511 Offline OP
#511  Offline OP
CT
Possible, if I can figure out the clogged water path and clear it. I had standing water in the cut outs under the engine mounts. And my weep holes in the stair cover lip don't drain. The area in front of the engine mounts appears to be solid. I'll check again.
0 registered members (), 28 guests, and 3 spiders.
First cruise
J/30 Items Still Available (Price Drop!):
by Gary Krogman. 03/30/20 04:20 PM
my boat stinks
by Rhapsody #348. 03/30/20 03:39 PM
J-30 tiller extension
by Gene A Trentham. 03/30/20 10:34 AM
Parts available
by apsimmonds. 03/25/20 06:02 PM
J80 Asym on J30
by usa1136. 03/16/20 06:27 PM
Zephyr needs another bow pulpit ASAP
by lumpy. 03/09/20 02:01 PM
by Koesh. 03/04/20 01:10 PM
WTB: Lower Shrouds (Replacement)
by Koesh. 03/04/20 01:03 PM
For Sale: Millennium, Hull #326- 1981
by Gordon Miskuin. 02/29/20 10:29 PM
Part number for engine stop cable
by Jon S. 02/24/20 01:45 PM
