4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30
Bill492, Syzygy, gseorget, Michael Foster, Maggie McN
1008 Registered Users
964,854 Dacron Main
159,395 Ananda's Refit
Topics3,964
Posts19,013
Members1,009
Most Online223
Dec 17th, 2019
Second bilge hose? #18366
12/15/19 09:48 PM
12/15/19 09:48 PM
CT
#511 Offline OP
#511  Offline OP
CT
I've searched the forums and can't find mention of a second bilge hose. I have a second bilge hose on #511. But I'm not sure where it goes. I can't find the other end.
The center grey bilge hose drains into the aft bilge sump. I ran a snake about 5' aft before it stopped. This would be just under the steps.
I used a camera to inspect the engine pan sumps and don't see anything.
Any ideas?
Greg
IMG_20191215_172833962.jpg [234.55 KBytes] - (276 downloads)
Aft bilge, #511
Re: Second bilge hose? [Re: #511] #18368
12/16/19 12:15 PM
12/16/19 12:15 PM
Charlottetown, Prince Edward I...
forbes Offline
forbes  Offline
Sounds like a drain hose from the molded lip which holds the edge of the engine cover? I noticed mine had two small holes draining water into a void which eventually worked its way back to the bilge. My hull does not have as much fiberglass on the aft end of the bilge platform area like yours does (yours seems to be sealed on the aft end). I think my bilge is relatively open on as it heads aft under the floor. Perhaps they closed it up and added a drain pipe after they got into the 500's. Just a guess.
Re: Second bilge hose? [Re: #511] #18369
12/16/19 01:26 PM
12/16/19 01:26 PM
CT
#511 Offline OP
#511  Offline OP
CT
Ah, that could be it. My drain holes don't drain. Prob need to be cleaned.
Thanks.
Re: Second bilge hose? [Re: #511] #18373
12/17/19 12:34 PM
12/17/19 12:34 PM
If you have a 2nd hose, it may address the problem others had draining aft of the steps. See this old thread - Dewatering Aft Bilge - Need Advice
Re: Second bilge hose? [Re: #511] #18374
12/17/19 01:44 PM
12/17/19 01:44 PM
CT
#511 Offline OP
#511  Offline OP
CT
Possible, if I can figure out the clogged water path and clear it. I had standing water in the cut outs under the engine mounts. And my weep holes in the stair cover lip don't drain. The area in front of the engine mounts appears to be solid. I'll check again.
0 registered members (), 33 guests, and 0 spiders.
First cruise
Need a J30 trailer
by Scot Benton. 09/22/23 12:48 PM
Newbie Electrical Questions
by Bob Rutsch. 09/11/23 02:09 PM
by Eggemoggin. 09/10/23 03:34 PM
Cockpit roles? Tiny cockpit!
by Patrick Stinson. 08/27/23 12:29 AM
Cut back V-Berth bulkhead?
by Patrick Stinson. 08/23/23 12:00 PM
by Patrick Stinson. 08/11/23 02:31 PM
Stripped Jib Halyard
by Bob Rutsch. 08/08/23 11:11 AM
Dockline fairleads
by Patrick Stinson. 07/31/23 03:57 AM
Wanted Used Main and #1 Genoa in Montreal or North East
by John McGuinness. 07/27/23 09:49 AM
