977,662 Dacron Main
163,105 Ananda's Refit
WTB: Lower Shrouds (Replacement) #18421
02/27/20 02:42 AM
02/27/20 02:42 AM
Portland, OR
Matt Arnold Offline OP
Portland, OR
One of the lower shrouds sprung a wire at the T Ball last season (see attached photo)
the specifications call for:
Lower Shrouds 17′ 2 3/4″ 1/4″ T Ball to Turnbuckle
but I was unable to source parts.
Is this something that is typically manufactured to order?
Given the critical nature of this part to structure/safety: Is there a preferred/trusted source that is commonly used?
appreciate the help/advice,
Sugar Plum, Hull #500, located in Portland, OR
SP_lowerShroud_sprung.jpg [142.23 KBytes] - (408 downloads)
Re: WTB: Lower Shrouds (Replacement) [Re: Matt Arnold] #18422
02/27/20 07:52 AM
02/27/20 07:52 AM
Rigrite has them Navtec / Gibb T-Ball Swage Fittings - N741-7 - measure the wire diameter to make sure you get the correct dash number.
Other J/30 spar parts at this link.
Re: WTB: Lower Shrouds (Replacement) [Re: Rhapsody #348] #18423
02/27/20 03:19 PM
02/27/20 03:19 PM
Portland, OR
Portland, OR
Thanks for that, Bill
to be clear: I am looking to purchase two new lower shroud assemblies with T-Ball, cable and turnbuckle built to spec.
(and I might just replace the uppers while I'm at it)
Just curious about what shops others have trusted to fabricate or source these.
Re: WTB: Lower Shrouds (Replacement) [Re: Matt Arnold] #18424
02/27/20 03:28 PM
02/27/20 03:28 PM
I would use a local rigger and have him get the parts. Anyone with a swage machine can make these. Provide the rigger the Rigrite link so parts may be purchased. That way the shrouds will be measured and built exactly to the length you have. The turnbuckles don't need to be Navtec since they are out of business. That way if a slightly longer or shorter turnbuckle is used, the rigger can compensate the wire length.
Re: WTB: Lower Shrouds (Replacement) [Re: Matt Arnold] #18425
02/27/20 05:46 PM
02/27/20 05:46 PM
Kailua Kona, HI
last fling IV Offline
Kailua Kona, HI
If you can't find someone closer, I used Andy Schwenk at Northwest rigging in Anacortes Wa. I replaced all shrouds and set the rig, then sailed to Hawaii. Rechecked tensions here,and they had not changed. Andy is a sailor and racer. email is "nwrig@cnw.com"
Re: WTB: Lower Shrouds (Replacement) [Re: Matt Arnold] #18426
02/28/20 02:24 AM
02/28/20 02:24 AM
Newport Beach, CA
Switchback Offline
Switchback  Offline
Newport Beach, CA
There are a couple of rigging shops in Portland. I don't have any experience dealing with them but found them online. West Coast Sailing, Rigging Products Inc, and Schooner Creek Boatworks. Schooner Creek is well known and might be the first place to try.
Re: WTB: Lower Shrouds (Replacement) [Re: Matt Arnold] #18428
03/04/20 01:03 PM
03/04/20 01:03 PM
St. Helens, OR USA
Koesh Offline
Koesh  Offline
St. Helens, OR USA
Hi Matt,
I have a J30 that I'm regrettably parting out. I have a complete boat with decent rigging. If you know someone looking for a J-30 as a project I'll make them a heckuva deal. 503 680-1914
Doug Marshall
Koeshtkah #207
Re: WTB: Lower Shrouds (Replacement) [Re: Matt Arnold] #18532
07/17/20 07:06 PM
07/17/20 07:06 PM
Queens, NY
B Davis Offline
B Davis  Offline
Queens, NY
This same exact breakage just happened to me. One strand of lower shroud broken at the t ball.
#1 Did you do much sailing on it after the one strand broke?
#2 Can anyone recommend a temporary rig tune that will put less stress on the lowers? I don’t intend to go out in 15kts it more, or in swell. I’m also just running a 100% Jib this season. Would it be crazy to go out for a day sail before this is replaced?
Thanks for everyone’s input over the years on this forum. I’m in my first J30 season and appreciating all the collective knowledge.
-Blaine
#410
Re: WTB: Lower Shrouds (Replacement) [Re: Matt Arnold] #18534
07/18/20 04:33 AM
07/18/20 04:33 AM
Scotland
J
Jim Hoey Offline
Jim Hoey  Offline
J
Scotland
Hi I would not risk it if one strand has broken you have no idea what condition the other strands are in.
Re: WTB: Lower Shrouds (Replacement) [Re: B Davis] #18535
07/18/20 10:59 AM
07/18/20 10:59 AM
Portland, OR
Portland, OR
This is a pretty easy replacement since it's not too high up the mast. I wouldn't risk any sailing since a shroud failure at the spreader could lead to much more dangerous (and expensive) damage to the mast.
Be careful /stay clear when you loosen the damaged shroud for removal in case it springs since you'll be right under it (and I would replace both since you're going through the trouble)
0 registered members (), 47 guests, and 1 spider.
