978,089 Dacron Main
163,254 Ananda's Refit
G Chart #18455
04/28/20 02:08 PM
04/28/20 02:08 PM
Onekama, MI
G
Gene A Trentham Offline OP
G
Onekama, MI
In search of the discontinued G chart for Lake Michigan, at least the southern half. Anybody?
BREAKAWAY
Hull #333
Sail #31884
Re: G Chart [Re: Gene A Trentham] #18456
04/28/20 06:42 PM
04/28/20 06:42 PM
What is a "G Chart?"
Re: G Chart [Re: Rhapsody #348] #18457
04/28/20 07:10 PM
04/28/20 07:10 PM
Onekama, MI
G
G
Onekama, MI
My apologies for not being clear. A G Chart is from Garmin and is a navigational chart to be inserted into one of their GPS's. They are discontinued and have been for many years. I have the choice of going back to my old Garmin GPSMAP 215 that uses G Charts. They, I believe were replaced with BLUECHARTS in later models. The built in world chart will suffice for what I need but not nearly with the detail as with a chart card. I have a northern Lake Huron I would be able to exchange for the Lake Michigan chart or I will just pay someone for it.
Thank you, I hope I cleared that up
BREAKAWAY
Hull #333
Sail #31884
Re: G Chart [Re: Gene A Trentham] #18458
04/30/20 11:03 AM
04/30/20 11:03 AM
Kittery, ME
--Ajax-- Offline
--Ajax--  Offline
Kittery, ME
I'm sure you are watching eBay, something will probably pop up eventually with enough time. On a side note, do you have an alternate plotting system for navigation? I have an old Garmin running the Bluechart chip (bought used chip off eBay) but I would not rely on 20 year old charts as my primary source for navigation. Channels shift, buoys are moved, new hazards may now be present.
I use Navionics as my primary nav software. For a $15/yr subscription I can run this on multiple devices, including a Samsung Galaxy tablet that I bought for $50 and my phone as a secondary device. Granted I'm not doing longterm cruising so the need for a full chart plotter is not there. Sounds like you may be in the same boat smile
Re: G Chart [Re: --Ajax--] #18459
04/30/20 03:58 PM
04/30/20 03:58 PM
Onekama, MI
G
G
Onekama, MI
Thanks Ajax
You're right I'm not planning on long term cruising with this boat. Have dug out the GPSMAP 215, 3 shades of grey color and am installing it on my "day sailer". i will be sailing it from Chicago to NW Lower Michigan and wanted a detailed chart installed in it.
thanks again, still looking
BREAKAWAY
Hull #333
Sail #31884
0 registered members (), 39 guests, and 1 spider.
