Re: Prop Shaft Cutlass Bearing
#1848
04/17/03 11:27 AM
04/17/03 11:27 AM
Posts: 127 Chicago, IL, US
rdpierce
Chicago, IL, US
While on the subject of prop shafts, bearings, etc....
What size stuffing should I use to re-pack my stuffing box?
Ryan Pierce, #337 rdpierce@pobox.com
Ryan Pierce, #337
#1849
04/17/03 02:44 PM
04/17/03 02:44 PM
I still have some packing material left over from the last time I did it. It's at the boat. I'll be able to check it this weekend. I don't remember off the top of my head.
The best thing to do would be to pull the current packing out of your packing nut and then buy something just a little bigger. I don't know if the packing nuts were the same on all J 30s.
#1850
04/19/03 10:08 PM
04/19/03 10:08 PM
Posts: 22 Severn, MD
BrianM
Severn, MD
Thanks for all the tips. Got the job done today.
I used Shunter's trick to get the shaft out of the shaft coupling. I put a 5/8's long socket in between the shaft coupling and transmission hub. Then using some extra long bolts, sandwiched it all together and popped the shaft out.
I used a hacksaw on the cutless bearing. Then used a chisel to break out the cut slice. The rest of it came out easy.
_______________________________ Joust - Hull #42
#1851
04/20/03 01:24 AM
04/20/03 01:24 AM
rdpierce
Chicago, IL, US
Congrats on pulling your cutless bearing!
By any chance did you find the packing size? I do intend to save what I pull, but I'm not sure how much it compresses down, and having a second opinion is always a good thing.
Ryan Pierce, #337
#1852
04/20/03 09:33 AM
04/20/03 09:33 AM
BrianM
Severn, MD
I forgot to get it for you. I knew I forgot something. I'm going to go back to the boat on Monday night. I'll make sure I get the size for you then.
#1854
04/21/03 10:34 PM
04/21/03 10:34 PM
BrianM
Severn, MD
Went to the boat tonight and found the packing. It was 1/4".
#1855
07/03/03 01:21 PM
07/03/03 01:21 PM
rdpierce
Chicago, IL, US
Thanks! 1/4" packing worked just fine.
Ryan
Ryan Pierce, #337
guests, and 1
spider. |
