loic, Cousineddy, Captain Rick, Boat Boxer, Hunter 34
914 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
841,327 Dacron Main
127,088 Ananda's Refit
Topics3,730
Posts18,281
Members914
Most Online223
Dec 17th, 2019
Wet bulkhead #18481
05/25/20 12:19 PM
05/25/20 12:19 PM
Morristown, NJ
Sumner_Parker Offline OP
Morristown, NJ
So, I was all set to just add four layers of glass to the ground down part as reinforcing and paint it in place of water damaged veneer. Thought it’s a good time to do something about high moisture readings in the bulkhead. Drilled a few holes… Top of the bulkhead is wet and mush; at the bottom of the long hole in photo it’s solid.
New plan is to cut another inch of the veneer away to the right and then cut across above the hole for the water/wiring, replace the plywood, cover with ten layers of glass, tab into hull and deck.
After drilling holes, appears that the strength of bulkhead for chainplates is in the glass on cabin side. Head side is just a few layers thick. Plywood separates the glass sides and adds compression strength to keep the hull from coming inwards.
Thoughts on:
-how much of old bulkhead core to replace?
-solid glass v plywood core for bulkhead?
-Glass layers, glass type, vacuum bag?
Didn’t see other threads that address this.
bulkhead.jpg [97.22 KBytes] - (163 downloads)
Re: Wet bulkhead [Re: Sumner_Parker] #18494
06/09/20 08:11 PM
06/09/20 08:11 PM
Morristown, NJ
Morristown, NJ
New plan. Removed cabinetry from head side and will replace section of rotted plywood core from there.
IMG_20200609_155244.jpg [103.82 KBytes] - (86 downloads)
Re: Wet bulkhead [Re: Sumner_Parker] #18495
06/10/20 08:52 PM
06/10/20 08:52 PM
Start reading my old blog at this link, then go to the newer pages in the blog.
1 registered members (Chris623), 16 guests, and 0 spiders.
First cruise
Shroud Tension Tuning
by usa1136. 08/02/20 11:01 AM
#484 "Conundrum" for sale
by nathankt79. 07/29/20 07:31 PM
by Koesh. 07/27/20 02:22 PM
Simple cruising douse
by Rajesh Verma. 07/20/20 07:05 AM
One of the best things about sailing offshore...
by Rajesh Verma. 07/20/20 07:04 AM
WTB: Lower Shrouds (Replacement)
by Rhapsody #348. 07/19/20 12:17 PM
3 way/Y-Valve handle
by Rhapsody #348. 07/10/20 03:53 PM
New North Main - too long?
by Georges. 07/01/20 02:27 PM
How to re-bed hand rails?
by Russ Atkinson. 07/01/20 10:36 AM
Where Can a Guy Get a Sink Around Here!?
by Koesh. 06/21/20 12:52 AM
