January
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Kenpickard, Danproawesome, Don N, George Leese, ShaneKilberg
926 Registered Users
862,164 Dacron Main
131,934 Ananda's Refit
Topics3,769
Posts18,395
Members927
Most Online223
Dec 17th, 2019
New North Main - too long? #18516
06/22/20 07:51 AM
06/22/20 07:51 AM
Belmont, MA
G
Georges Offline OP
Georges  Offline OP
G
Belmont, MA
Hi team,
I hoisted my new North main for the first time yesterday. It seemed too long: by a couple of inches. Still a few wave along the luff slugs (no rope).
I was in a rush and will not be able to actually measure the luff before next weekend
A cunningham can handle it.
But it looks more like a mistake - although I find hard to believe that North Newport would make such an error on this class.
I have a shackle spliced on 5/16 dyneema halyard on the head, that might cost me an inch of luff but there is more than that here.
Any of you have similar experience? with North?
-- Georges
Re: New North Main - too long? [Re: Georges] #18517
06/24/20 03:56 AM
06/24/20 03:56 AM
Scotland
J
Jim Hoey Offline
Jim Hoey  Offline
J
Scotland
Hi Georges,
I've got North 3 Di
Luff is 11.55 M
Re: New North Main - too long? [Re: Georges] #18518
06/24/20 10:49 AM
06/24/20 10:49 AM
BC
P
Pabs Offline
Pabs  Offline
P
BC
Did you not have North come out and measure?
Re: New North Main - too long? [Re: Pabs] #18519
06/24/20 04:27 PM
06/24/20 04:27 PM
Belmont, MA
G
Georges Offline OP
Georges  Offline OP
G
Belmont, MA
They told me they did.
I will live through the season with a cunningham. They were responsive and open and told me an easy fix if it needs.
I will top my halyard this week-end and measure everything precisely.
Will also try to reduce as much I can on the top by not attaching directly the halyard but through a loop.
I guess my real question was: do you need to do any halyard trick - like not using a shackle - or less than 5/16 spliced halyard to max you OD main luff?
Cheers,
-- Georges
Re: New North Main - too long? [Re: Georges] #18526
07/01/20 01:27 PM
07/01/20 01:27 PM
Belmont, MA
G
Georges Offline OP
Georges  Offline OP
G
Belmont, MA
Just to close that thread. Issue was only mine.
The main (NPC Nordac Radian 7.5) was perfect. Luff length was 37' 9 1/2" that is 2" 1/2 below max class length which is fine for me. (about 1" shorter than your 3Di Jim). 38" is exactly the max I get with my halyard topped out.
After spending more time on this, cleaning up a bit the mast groove, measuring with tack free. it at the ends boils down to this new main being really the first true class legal one I have on this boat.
My prior main was a bit shorter, shorter enough for me to deal with luff tension only with the halyard tension. Not something I can do anymore with this one.
all set. thanks fellows.
-- Georges
0 registered members (), 39 guests, and 0 spiders.
First cruise
Self Tailing Winch
by Chris Edwards. 01/18/21 07:22 AM
COMPLETE SET OF UPPER/LOWER RUDDER GUDGEONS, PINS $325.00
by Rhapsody #348. 01/16/21 06:55 PM
by B Davis. 01/16/21 03:24 PM
Introduction and Asking for Advice
by neumannaudio. 01/15/21 04:00 PM
Wanted - Triple Deck Organizer - Found One
by B Davis. 01/05/21 03:36 PM
Stern Perch Seats
by Michael L. 01/05/21 09:19 AM
prebend
by Claribertz. 12/30/20 03:43 AM
Winter boat cover
by Gene A Trentham. 12/18/20 03:37 PM
Engine Housing Access Hatch
by Michael L. 12/18/20 03:32 PM
Aluminium Spinnaker Pole
by Michael L. 12/18/20 02:17 PM
