New North Main - too long?
#18516
06/22/20 08:51 AM
06/22/20 08:51 AM
Posts: 88 Belmont, MA
Georges
Belmont, MA
Hi team, I hoisted my new North main for the first time yesterday. It seemed too long: by a couple of inches. Still a few wave along the luff slugs (no rope).
I was in a rush and will not be able to actually measure the luff before next weekend A cunningham can handle it. But it looks more like a mistake - although I find hard to believe that North Newport would make such an error on this class. I have a shackle spliced on 5/16 dyneema halyard on the head, that might cost me an inch of luff but there is more than that here.
Any of you have similar experience? with North?
Re: New North Main - too long?
[Re: Pabs]
#18519
06/24/20 05:27 PM
06/24/20 05:27 PM
Georges
Belmont, MA
They told me they did. I will live through the season with a cunningham. They were responsive and open and told me an easy fix if it needs. I will top my halyard this week-end and measure everything precisely. Will also try to reduce as much I can on the top by not attaching directly the halyard but through a loop.
I guess my real question was: do you need to do any halyard trick - like not using a shackle - or less than 5/16 spliced halyard to max you OD main luff? Cheers,
[Re: Georges]
#18526
07/01/20 02:27 PM
07/01/20 02:27 PM
Georges
Belmont, MA
Just to close that thread. Issue was only mine. The main (NPC Nordac Radian 7.5) was perfect. Luff length was 37' 9 1/2" that is 2" 1/2 below max class length which is fine for me. (about 1" shorter than your 3Di Jim). 38" is exactly the max I get with my halyard topped out. After spending more time on this, cleaning up a bit the mast groove, measuring with tack free. it at the ends boils down to this new main being really the first true class legal one I have on this boat. My prior main was a bit shorter, shorter enough for me to deal with luff tension only with the halyard tension. Not something I can do anymore with this one.
all set. thanks fellows.
44
guests, and 14
