loic, Cousineddy, Captain Rick, Boat Boxer, Hunter 34
914 Registered Users
West Marine Affiliate Link
J/30 Class Affiliate Program
841,327 Dacron Main
127,088 Ananda's Refit
Topics3,730
Posts18,281
Members914
Most Online223
Dec 17th, 2019
How to re-bed hand rails? #18520
06/27/20 03:56 PM
06/27/20 03:56 PM
Seattle
K
Kellen Offline OP
Kellen  Offline OP
K
Seattle
Okay J/30 newbie question here. I’ve got rain water dripping down the interior ceiling handrails. Do the exterior rails thru-bolt into the interior rails? How do these things come off? It would be awesome if I didn’t have to remove the plugs on the interior rail because finding Ash plugs doesn’t seem like an easy task and I really don’t want to have to re varnish. Can it be done from just the top? Teak plugs are easy to find, and I think the exterior is just finished in teak oil.
Mouse #359
Re: How to re-bed hand rails? [Re: Kellen] #18521
06/27/20 06:19 PM
06/27/20 06:19 PM
Kellen - they are through bolted with bungs covering top & bottom. I don't think you would be able to remove one side as the opposite end needs to be held to unscrew the nut.
Re: How to re-bed hand rails? [Re: Kellen] #18522
06/29/20 12:50 PM
06/29/20 12:50 PM
Rockwood, MI, USA
Russ Atkinson Online content
Russ Atkinson  Online Content
Rockwood, MI, USA
Take the plugs out of the top teak rails, under the plug there is a nut and washer to back off (I had no problem doing this).. Pull top rails off as well as inside rails. Drill oversize holes and fill with epoxy. Re-drill, holes for the screws that are coming out of inside rails - take your time to make sure you center the new holes in the epoxy. Re-bed top and inside
Re: How to re-bed hand rails? [Re: Kellen] #18523
06/29/20 06:33 PM
06/29/20 06:33 PM
Seattle
K
Kellen Offline OP
Kellen  Offline OP
K
Seattle
Thanks for detailed info. Hopefully Russ is right and I don't have to remove the plugs on the interior rails.
Mouse #359
Re: How to re-bed hand rails? [Re: Kellen] #18524
06/30/20 11:43 PM
06/30/20 11:43 PM
Mine were frozen when I had to remove the top rail so I had to remove upper and lower.
Re: How to re-bed hand rails? [Re: Kellen] #18525
07/01/20 10:36 AM
07/01/20 10:36 AM
Rockwood, MI, USA
Rockwood, MI, USA
If it turns out you have to pull the plugs out of the inside rails, I have some ash laying around as well as plug cutters. Just let me know the size of the plugs and how many
1 registered members (Chris623), 16 guests, and 0 spiders.
First cruise
Shroud Tension Tuning
by usa1136. 08/02/20 11:01 AM
#484 "Conundrum" for sale
by nathankt79. 07/29/20 07:31 PM
by Koesh. 07/27/20 02:22 PM
Simple cruising douse
by Rajesh Verma. 07/20/20 07:05 AM
One of the best things about sailing offshore...
by Rajesh Verma. 07/20/20 07:04 AM
WTB: Lower Shrouds (Replacement)
by Rhapsody #348. 07/19/20 12:17 PM
3 way/Y-Valve handle
by Rhapsody #348. 07/10/20 03:53 PM
New North Main - too long?
by Georges. 07/01/20 02:27 PM
by Russ Atkinson. 07/01/20 10:36 AM
Where Can a Guy Get a Sink Around Here!?
by Koesh. 06/21/20 12:52 AM
