Bil, I still have the original Origo pressure alcohol stove. I'll pull it out and test it. As I said above if you'll send me an email I'll send you photos. I'm at: ravenracingdoug@gmail.com Are you after lifelines or the cabintop grabrails? I made up heavier teak cabintop rails...they should clean up fine. Doug.
Doug Marshall Koeshtkah #207
Re: For Sale or Parts #207 Koeshtkah
[Re: Koesh]
#18529 07/14/2001:27 PM07/14/2001:27 PM
Hi Doug, Apologies for finally getting back to you - we’ve been gearing up to head out to sea for work, which turns out to be tricky in the middle of a pandemic. I’m still interested in the head sink, and am also interested in the prop and shaft assembly if it’s straight and in good shape, might be interested in your injectors too if they’re in good shape. Our final port call is in Newport, OR near the beginning of September- I could swing by on the way back up to WA to pick the things up? Let me know what you think!
Mouse #359
[Re: Kellen]
#18530 07/14/2004:49 PM07/14/2004:49 PM
Hi Kellen, Sounds great! I have the entire drive train so I can pull the shaft, prop and coupler and check the shaft on some v-blocks for straightness. There was no perceptible vibration on it prior to pulling (other than the usual Yanmar stuff), but I should make sure it didn't get a strap around it during the lift at Schooner Creek. Will you be in reach during your sea duty? That'll give me time to pull the sink and everything, too.
[Re: Koesh]
#18531 07/17/2005:31 PM07/17/2005:31 PM
Hi Doug, I'll have email (rosburk AT my DOT uri DOT edu). Shoot me an email and we can get the conversion rolling about the financial aspect too. Thanks!
Mouse #359
[Re: Koesh]
#18533 07/17/2007:18 PM07/17/2007:18 PM
