March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,359 Dacron Main
162,678 Ananda's Refit
Wet bulkhead #18481
05/25/20 12:19 PM
05/25/20 12:19 PM
Morristown, NJ
Sumner_Parker Offline OP
Morristown, NJ
So, I was all set to just add four layers of glass to the ground down part as reinforcing and paint it in place of water damaged veneer. Thought it’s a good time to do something about high moisture readings in the bulkhead. Drilled a few holes… Top of the bulkhead is wet and mush; at the bottom of the long hole in photo it’s solid.
New plan is to cut another inch of the veneer away to the right and then cut across above the hole for the water/wiring, replace the plywood, cover with ten layers of glass, tab into hull and deck.
After drilling holes, appears that the strength of bulkhead for chainplates is in the glass on cabin side. Head side is just a few layers thick. Plywood separates the glass sides and adds compression strength to keep the hull from coming inwards.
Thoughts on:
-how much of old bulkhead core to replace?
-solid glass v plywood core for bulkhead?
-Glass layers, glass type, vacuum bag?
Didn’t see other threads that address this.
bulkhead.jpg [97.22 KBytes] - (437 downloads)
Re: Wet bulkhead [Re: Sumner_Parker] #18494
06/09/20 08:11 PM
06/09/20 08:11 PM
Morristown, NJ
Morristown, NJ
New plan. Removed cabinetry from head side and will replace section of rotted plywood core from there.
IMG_20200609_155244.jpg [103.82 KBytes] - (397 downloads)
Re: Wet bulkhead [Re: Sumner_Parker] #18495
06/10/20 08:52 PM
06/10/20 08:52 PM
Start reading my old blog at this link, then go to the newer pages in the blog.
Re: Wet bulkhead [Re: Sumner_Parker] #18551
08/04/20 12:32 PM
08/04/20 12:32 PM
Vancouver, BC, Canada
dlabrosse Offline
dlabrosse  Offline
I had a similar issue with 1/3 of my entire bulkhead soaked. The plywood had essentially dissolved. In the end I had a local boatyard cut out the entire bulkhead and replace it. Foam core, glassed along the top (like it shoaled have been in the first place) and solid glass at the chainplates.
Dominique Labrosse
Red Five, #92
0 registered members (), 35 guests, and 1 spider.
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
