977,822 Dacron Main
163,185 Ananda's Refit
3 way/Y-Valve handle #18527
07/06/20 03:54 PM
07/06/20 03:54 PM
BC
P
Pabs Offline OP
Pabs  Offline OP
P
BC
Hi,
My Y-Valve handle has broken and they don't manufacture it any more. Other then replacing the existing valve does anyone know where I can get a new handle for it?
Thanks
handle.jpg [249.52 KBytes] - (182 downloads)
Re: 3 way/Y-Valve handle [Re: Pabs] #18528
07/10/20 03:53 PM
07/10/20 03:53 PM
Based on the age, your sanitary piping may also be as brittle if it hasn't been replaced. The Bosworth Sea-leact valves are available in newer models that should fit where the old valve was.
Re: 3 way/Y-Valve handle [Re: Pabs] #18571
08/31/20 01:47 PM
08/31/20 01:47 PM
Squamish, British Columbia
NaturalHigh Offline
NaturalHigh  Offline
I have the Forespar Y valves that seem to operate pretty smoothly. I lubed the heck out of the inside with Vaseline before installing them.
https://ca.binnacle.com/Plumbing-&a...ar-Marelon-MF-Y-Valves/product_info.html
