Re: Quieting lines in mast at anchor
[Re: Rob Van Name]
#18896
09/08/21 11:57 AM
09/08/21 11:57 AM
Posts: 39 Seward, AK
Patrick Stinson
Seward, AK
The electrical mast lines were not secured in my boat from the factory. Hull #406. So then I assume you have this problem too??
[Re: Patrick Stinson]
#18912
10/04/21 07:13 PM
10/04/21 07:13 PM
Posts: 88 Belmont, MA
Georges
Belmont, MA
I did pay attention (and it is tricky) making sure the halyards are not twisted around the electric wire... and around other halyards for that matter. Making sure is probably an overstatement - since it is quite hard visually - so I use more like a feel hoisting keeping/touching the other halyard to "feel" if any friction....
I also used the spreader reinforcement as a forward backward split: main halyard and foamed wrappd wire behind - jibs halyard in front.
In term of rigid tubing - I tried light and simple at first - and since it worked did not get further :-)
41
guests, and 14
