978,183 Dacron Main
163,283 Ananda's Refit
Cleaning fuel tank #18581
09/01/20 12:16 PM
09/01/20 12:16 PM
Squamish, British Columbia
NaturalHigh Offline OP
Hi all,
I have gone in through the inspection cover on my fuel tank to clean it out before, but there is a large baffle between the inspection port and the fuel pick up. This has prevented me from truly cleaning the deepest part of the tank so far. How have others dealt with this? Cut a new inspection port on the other side of the baffle?
Re: Cleaning fuel tank [Re: NaturalHigh] #18583
09/02/20 04:58 AM
09/02/20 04:58 AM
Scotland
J
Jim Hoey Offline
Jim Hoey  Offline
J
Scotland
Hi I removed the tank sloshed it around then emptied the tank.
0 registered members (), 45 guests, and 1 spider.
