Propane Locker
#17623
01/22/18 11:25 PM
01/22/18 11:25 PM
Posts: 218 Scappoose, OR
Coastie
Scappoose, OR
I tried to use an old thread that had an unrelated title on water in the bilge. My question is about a propane locker and the options.
I need to resurrect this thread. On MaJic Carpet the lazarettes both have a storage box inside them, neither has any kind of drain to the outside of the hull. I do want to use the stove so need to sort out a solution. I'm having a hard time seeing any easy solutions to this problem. On some cruising boats I have noticed that the tanks are actually mounted on the transom, not a very elegant solution. I was thinking about just securing the tank inside the cockpit and using the scuppers for the venting, but that seems to fail the drain being 20" away from any other opening.
48
guests, and 13
