October
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30 31
the_professor, tfrikker, Phil Spletter, kvaschik, mattjenPDX71
919 Registered Users
851,559 Dacron Main
129,496 Ananda's Refit
Topics3,757
Posts18,354
Members919
Most Online223
Dec 17th, 2019
Propane Locker #17623
01/22/18 11:25 PM
01/22/18 11:25 PM
Scappoose, OR
Coastie Offline OP
Coastie  Offline OP
Scappoose, OR
I tried to use an old thread that had an unrelated title on water in the bilge. My question is about a propane locker and the options.
I need to resurrect this thread. On MaJic Carpet the lazarettes both have a storage box inside them, neither has any kind of drain to the outside of the hull. I do want to use the stove so need to sort out a solution. I'm having a hard time seeing any easy solutions to this problem. On some cruising boats I have noticed that the tanks are actually mounted on the transom, not a very elegant solution. I was thinking about just securing the tank inside the cockpit and using the scuppers for the venting, but that seems to fail the drain being 20" away from any other opening.
Re: Propane Locker [Re: Coastie] #18585
09/11/20 03:59 AM
09/11/20 03:59 AM
Seward, AK
P
Patrick Stinson Offline
P
Seward, AK
I am also curious if anyone can suggest a propane tank and locker. It looks like the port lazarette once had a tank mounted in it.
Re: Propane Locker [Re: Coastie] #18587
09/11/20 10:01 AM
09/11/20 10:01 AM
Rockwood, MI, USA
Russ Atkinson Offline
Rockwood, MI, USA
The new design cockpit/cabin arrangement has a propane storage locker in the cockpit. Can't speak to the old configuration
Re: Propane Locker [Re: Coastie] #18588
09/11/20 11:04 AM
09/11/20 11:04 AM
Grand Haven, MI
Brian Kelly Offline
Brian Kelly  Offline
Grand Haven, MI
I am told that the new deck design started at hull 452 and the new cabin layout started at hull 455. We have hull 454 which is new deck old cabin.
Re: Propane Locker [Re: Coastie] #18594
09/11/20 09:05 PM
09/11/20 09:05 PM
Rockwood, MI, USA
Rockwood, MI, USA
We have one Quarter berth which is on the Starboard side. We have a propane locker all the way aft on the starboard side but no storage locker. Apparently the tweener boats aren't quite the same
Re: Propane Locker [Re: Coastie] #18595
09/12/20 05:49 PM
09/12/20 05:49 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
This one is gigantic & expensive but includes the tank:
https://www.defender.com/product.jsp?id=3473225
Re: Propane Locker [Re: Coastie] #18603
09/22/20 06:47 PM
09/22/20 06:47 PM
Squamish, British Columbia
NaturalHigh Offline
NaturalHigh  Offline
If you look closely, the storage boxes in the lazarette do drain into the cockpit with a hole. Not really big enough for a full size tank though. This is where I keep my green bbq cans though when cruising because there is an "outside drain"
0 registered members (), 39 guests, and 0 spiders.
First cruise
2 Main sails for sale!!
by deathtrap30. 10/18/20 10:17 AM
Sails: Main, Unknown, #2, #3, Spinnaker in CA
by deathtrap30. 10/18/20 10:14 AM
by deathtrap30. 10/18/20 09:57 AM
Main sail Dacron $700.00
by deathtrap30. 10/18/20 09:55 AM
Halyard + Sheet Guide
by Rhapsody #348. 10/16/20 10:00 AM
2 Schaefer jib sheet car twin line $200.00
by Sts. 09/30/20 02:51 PM
Yanmar fuel injector $100.00
by Sts. 09/30/20 02:35 PM
Roller Furling?
by Bill Veno. 09/30/20 02:29 PM
Yanmar injection pump $ 450.00
by Sts. 09/30/20 02:17 PM
# 1 Genoa kevlar$700.00
by Sts. 09/30/20 01:59 PM
