March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,347 Dacron Main
162,673 Ananda's Refit
Remove anchor well #18707
03/08/21 04:52 PM
03/08/21 04:52 PM
Morristown, NJ
Sumner_Parker Offline OP
Morristown, NJ
In the process of recoring the starboard bulkhead. I’m going in from the forward side (see photo), but the anchor well is in the way. Is there a way to remove this? I undid all the screws, but there is no good way I see to pry it loose from the deck. Suggestions?
PXL_20210220_211604574.jpg [133.87 KBytes] - (149 downloads)
Re: Remove anchor well [Re: Sumner_Parker] #18708
03/08/21 07:04 PM
03/08/21 07:04 PM
That bulkhead is tabbed in as it is a major structural piece and will need to be cut out.. Whatever you replace it with must be tabbed to the hull.
0 registered members (), 52 guests, and 1 spider.
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
