Running halyards through sheave box
#18724
03/22/21 08:26 PM
03/22/21 08:26 PM
Posts: 493 Chicago, Il. USA
D. Bartley
Chicago, Il. USA
My sheave box has sheaves in the front for 2 jibs and a spinnaker. Behind each of them is another smaller sheave.
Do you run each halyard between the front and back sheave, or do you run them over each sheave?
ty
Re: Running halyards through sheave box
[Re: Rhapsody #348]
#18727
03/24/21 11:43 AM
03/24/21 11:43 AM
D. Bartley
Chicago, Il. USA
Ty Bill. Running it over both does seem logical. I have the mast down and sheave box out, so that's easy.
However... if you were trying to feed a halyard with the mast up, it would seem a bit difficult to get the bicycle chain over the aft sheave. There's probably a riggers trick to do that.
[Re: D. Bartley]
#18730
04/01/21 10:31 AM
04/01/21 10:31 AM
Posts: 32 Kittery, ME
--Ajax--
Kittery, ME
I was able to get a tracing line with bike chain over the second sheave with a little help from a bent coat hangar, this was for my main halyard.
[Re: D. Bartley]
#18736
04/05/21 10:46 AM
04/05/21 10:46 AM
D. Bartley
Chicago, Il. USA
Thanks. I won't ask how you managed to get up to the masthead in order to run that halyard.
44
guests, and 14
