978,305 Dacron Main
163,315 Ananda's Refit
Folding prop #18742
04/11/21 11:13 PM
04/11/21 11:13 PM
Los Angeles, CA
Austin Offline OP
Austin  Offline OP
Los Angeles, CA
Hey guys I just bought a 1982 j30, it has the typical yanmar 2GM diesel with 2.62 gearing. Unfortunately the blades to the Martec prop that was on the boat came off while motoring to my slip. I’m now looking for a new prop and was told the best way to go is the varifold. Does anyone have any idea of the proper pitch and size of the blades that would be used? Any info would be greatly appreciated.
Re: Folding prop [Re: Austin] #18743
04/12/21 08:32 AM
04/12/21 08:32 AM
New York
P
pez Offline
pez  Offline
P
New York
I replaced my prop 2 years ago when I bought the boat, came with a fixed 2 blade.
I ended up going with a Gori Folding Std 2-blade - 15" x 10 x 2-blade RH.
"The sea is selective; slow at recognition of effort and aptitude, but fast in sinking the unfit." - Felix Riesenberg
Re: Folding prop [Re: Austin] #18744
04/13/21 05:37 PM
04/13/21 05:37 PM
Los Angeles, CA
Austin Offline OP
Austin  Offline OP
Los Angeles, CA
Ended up going with the verifold prop. Thank you guys
