March
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
1017 Registered Users
976,225 Dacron Main
162,648 Ananda's Refit
Heater location / Cabin pan profile? #18806
05/30/21 03:21 PM
05/30/21 03:21 PM
Seward, AK
P
Patrick Stinson Offline OP
P
Seward, AK
I am trying to think of a good install location for a Webasto (Evo 40) heater. I'm thinking on the floor aft of the engine to the port of centerline, with the 90mm output duct in the small wall under the starboard quarter berth between the stairs and the ice box. I have a used 90 degree aluminum mount from a previous install that will mount the heater to a floor or wall.
It looks like the floor aft of the engine and stuffing box is not the hull itself but a pan insert. Does anyone know how much clearance I have underneath this for screws to poke through? And is it glassed to the hull (i.e. no clearance) in the middle but tapering up (i.e. with increasing clearance) as it goes laterally toward the quarter berths? I guess a cross section would be helpful.
Thanks!
Re: Heater location / Cabin pan profile? [Re: Patrick Stinson] #18879
08/13/21 05:42 PM
08/13/21 05:42 PM
Squamish, British Columbia
NaturalHigh Offline
NaturalHigh  Offline
Mine is not a pan, it is the hull itself.
I mounted a diesel heater to the wood bulkhead on the port side in that space, rather than to the floor. The air outlet comes out as you described but under the port quarter berth aft of the galley.
Re: Heater location / Cabin pan profile? [Re: Patrick Stinson] #18880
08/13/21 06:18 PM
08/13/21 06:18 PM
Seward, AK
P
P
Seward, AK
Turns out mine has a pan insert with varying clearance but plenty to drill through carefully without hitting the hull. Installation was easy on the insert with an aluminum bracket. Outlet duct is below starboard quarterberth.
Re: Heater location / Cabin pan profile? [Re: Patrick Stinson] #18926
10/26/21 05:09 PM
10/26/21 05:09 PM
BC
P
Pabs Offline
Pabs  Offline
P
BC
I installed mine to the bulkhead behind the engine. Works really well
Cabin Table Wanted
by B Davis. 01/20/24 11:03 PM
Fuel Fill O Ring
