977,822 Dacron Main
163,185 Ananda's Refit
Re: Prop Strut Ridiculousness [Re: Russ Atkinson] #16901
07/19/16 09:08 PM
07/19/16 09:08 PM
Northfield, MN
H
Hushgully Offline
Hushgully  Offline
H
Northfield, MN
Super! Primarily the base plate was effected. Hadn't considered the engine alignment. I'll make sure to include that process in the reassembly.
Thanks for the help
Ken
Re: Prop Strut Ridiculousness [Re: Hushgully] #18779
05/09/21 02:23 AM
05/09/21 02:23 AM
Seattle
K
Kellen Offline
Kellen  Offline
K
Seattle
I think I've run into a similar situation to what was described here (see photo below). It looks likes someone did a crappy job with faring epoxy and it has separated from the hull. I guess the big question here is, how bad is this? Like a fix it right now problem or a fix it in a few months problem? (money and time are the limiting factors at the moment).
IMG_9284.JPG [138.83 KBytes] - (214 downloads)
Mouse #359
Re: Prop Strut Ridiculousness [Re: JBiermann] #18803
05/24/21 05:53 PM
05/24/21 05:53 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
The boat yard had a new 3/4 " shaft built for me a decade ago. They didn't like the wear on the key ways. It was done at a propeller shop of unknown origin...Good luck with this caper.
Re: Prop Strut Ridiculousness [Re: JBiermann] #18819
06/08/21 01:43 PM
06/08/21 01:43 PM
Miami, Florida USA
the redhead Offline
the redhead  Offline
Miami, Florida USA
I have the strut, shaft and transmission connect, plus a dripless packing unit... was to be installed in my boat. Before hurricanes
Re: Prop Strut Ridiculousness [Re: JBiermann] #18820
06/08/21 01:46 PM
06/08/21 01:46 PM
Miami, Florida USA
the redhead Offline
the redhead  Offline
Miami, Florida USA
strut, shaft, packing non dripless available 3/4 inch
