977,822 Dacron Main
163,185 Ananda's Refit
Table mods #18842
06/27/21 11:01 PM
06/27/21 11:01 PM
Lewisville TX USA
H
Hull516 Offline OP
Hull516  Offline OP
H
Lewisville TX USA
Original table was lost, so tried these mods: moved table forward, rule joint for drop leaves, widen leaves sobtheir arc just clears port and starboard cushions, use two inch PVC to fit as a sleeve over pipe/legs.
Wood used here was - padauk for centerboard, ash for drop leaves. Seems to both increase table surface area and cabin movement....might even convert to part of a bed in future.
0EE3DA71-9149-4FF5-9E0F-CBBCCA1C074F.png [860.4 KBytes] - (212 downloads)
Re: Table mods [Re: Hull516] #18845
07/06/21 09:30 AM
07/06/21 09:30 AM
Kittery, ME
--Ajax-- Offline
--Ajax--  Offline
Kittery, ME
Nice work!
