June
5 6 7 8 9 10 11
12 13 14 15 16 17 18
19 20 21 22 23 24 25
26 27 28 29 30
Benz @ North, David Hulse, littoraldrift, Windchill, knh555
1001 Registered Users
956,033 Dacron Main
156,472 Ananda's Refit
Topics3,945
Posts18,946
Members1,002
Most Online223
Dec 17th, 2019
Natural weakening in deck under stanchion bases #18825
06/15/21 03:05 AM
06/15/21 03:05 AM
Seward, AK
P
Patrick Stinson Offline OP
P
Seward, AK
The deck around many of my lifeline stanchion bases looks like it's weakened. The deck moves when I push and pull hard on the stancions. There isn't any fiberglass cracking that I can see, but the deck just seems to have lost its rigidity. Is this normal wear and tear for a 40 year (#354) J/30? What have others done to repair/improve it? Extra glass? Extra large backing plates?
Wet core is not a factor with these bolt hole placements.
I have read every post here with the word "stanchions" in it.
Re: Natural weakening in deck under stanchion bases [Re: Patrick Stinson] #18839
06/22/21 05:46 PM
06/22/21 05:46 PM
Westerly, RI
Chris623 Offline
Chris623  Offline
Westerly, RI
Like many boats, #357 had this same issue before I purchased her. The PO had Waterline Systems address this by using a top side G10 stiffener plate that spread the load out. Over the years however, there was water infiltration from a path formed between the top and bottom skins in that area in your picture which has no core. This path caused wet core near a couple of these stanchion bases which I later repaired by recoring from the top, then applying AwlGrip & Griptex. This improved the stability of the stanchions. In your case, I would be curious if there was any wet core in that area or delamination, which you might detect with a moisture meter, hammer and maybe a core drill sample from the bottom side. If it turns out to be sound and dry, you might be able to restore some structure with a G10 plate glassed onto the bottom skin.
GL,
-Chris
StanchionBase.JPG [17.7 KBytes] - (17 downloads)
Re: Natural weakening in deck under stanchion bases [Re: Chris623] #18840
06/22/21 05:59 PM
06/22/21 05:59 PM
Seward, AK
P
P
Seward, AK
The core was good, though I didn't follow what you meant about how water could get into the core since these stanchions don't penetrate the core there. At any rate, I added a fix that is similar in concept to yours except by reenforcing with plywood and new glass. (Photo is pre-sand and gelcoat, of course ;))
We'll see how that works.
IMG_4181.jpg [47.11 KBytes] - (11 downloads)
IMG_4182.jpg [95.83 KBytes] - (13 downloads)
Re: Natural weakening in deck under stanchion bases [Re: Patrick Stinson] #18857
07/20/21 08:22 PM
07/20/21 08:22 PM
Miami, Florida USA
the redhead Offline
the redhead  Offline
Miami, Florida USA
Hi, I had similar so when I replaced my stanchions I used G10 for backing. Used the same size as the original backing plates.... but G10 is far stonger than anything else. You can get it a Grainger. Its fiberglass pressed in high tensile strength for insulation? Commercial applications. Must be cut by a shop saw and drilled... none of my hand tools would get thru it.
0 registered members (), 40 guests, and 0 spiders.
First cruise
Spinnaker Mast Track Needed
by pez. 06/08/23 05:55 PM
Zephyr V2.0 For Sale
by Breezin454. 06/06/23 03:08 PM
Sliding hatch channel source
by Breezin454. 06/04/23 08:31 PM
Replacement table legs
by Navy Dan. 06/04/23 06:12 PM
Fuel tank replacement
by Navy Dan. 06/02/23 05:52 PM
Dockline fairleads
by Patrick Stinson. 05/30/23 09:02 PM
Barber hauler
by Navy Dan. 05/29/23 07:13 PM
Head door
by Steve Buzbee. 05/23/23 05:49 PM
For Sale: 1982 (Hull 434) "ENCOUNTER"
by David Hulse. 05/19/23 09:42 AM
