October
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Eloise, Dogswater, Orcamike, GreyJay, David G
969 Registered Users
897,177 Dacron Main
141,855 Ananda's Refit
Topics3,838
Posts18,648
Members969
Most Online223
Dec 17th, 2019
Replacing transducer #18851
07/18/21 09:20 PM
07/18/21 09:20 PM
Falmouth, MA
Ryan Anderson Offline OP
Falmouth, MA
Is there no balsa core where the head's seacock is? I'm going to replace a transducer that is in that area and want to know what I'm getting into. It seem that there is a square area where the inner skin dips down, my guess is there is no balsa core in this square?
If anyone has any tips on replacing the existing transducer that would be helpful. The new one will be the exact same diameter. It seems the biggest challenge is getting the old one out. I would like to avoid hammering it out, so I was thinking of cutting it up with a rotary tool.
Re: Replacing transducer [Re: Ryan Anderson] #18852
07/18/21 10:33 PM
07/18/21 10:33 PM
That area should be without core. If the old transducer is scrap, drill through the center of it from the bottom to make a pilot hole, then use a circle cutter the diameter of the housing threads. The transducer and old housing will pull out easily from inside the boat. Clean up the area and bed the new transducer housing.
Re: Replacing transducer [Re: Ryan Anderson] #18853
07/19/21 07:15 AM
07/19/21 07:15 AM
Falmouth, MA
Falmouth, MA
Thanks Bill, that's useful information.
The old thru-hole is actually a speed sensor. I'll put in the plug and drill a pilot hole in that.
Any favorite bedding products? 4200?
A separate question, does the cockpit bulkhead have a core?
Re: Replacing transducer [Re: Ryan Anderson] #18854
07/19/21 07:44 AM
07/19/21 07:44 AM
You can use closed cell pipe foam with a wooden dowel in the center, then pushed in the insert to provide a place to drill the pilot hole. That is what I did.
Use Sikaflex-291 for bedding the insert. It is quick setting marine grade polyurethane and cleans up with mineral spirits.
The cockpit bulkhead is cored. If you drill to mount something there, be sure to properly epoxy isolate.
Re: Replacing transducer [Re: Rhapsody #348] #18868
08/04/21 06:55 PM
08/04/21 06:55 PM
Falmouth, MA
Falmouth, MA
The wooden dowel trick worked. I only drilled through the flange, then was able to rotate the old sensor out. It wasn't bedded with a permanent material.
Re: Replacing transducer [Re: Ryan Anderson] #18871
08/05/21 07:44 AM
08/05/21 07:44 AM
Ryan - what hull number do you have? You aren't shown on the boat list and I can fix that.
Re: Replacing transducer [Re: Rhapsody #348] #18872
08/05/21 10:47 AM
08/05/21 10:47 AM
Falmouth, MA
Falmouth, MA
456, I recently purchased her from Bill. Haven't changed the name, you can put me down for MA for state.
Re: Replacing transducer [Re: Ryan Anderson] #18874
08/06/21 09:28 AM
08/06/21 09:28 AM
Got it - That explains why I haven't seen Bill out on Tuesday nights. Dave Erwin is fixing the database SW and as soon as he does, I'll make the update.
Re: Replacing transducer [Re: Ryan Anderson] #18889
08/21/21 10:28 AM
08/21/21 10:28 AM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
What kind of transducer?
If it is depth just silicon it to the center area under the vee berth.
Re: Replacing transducer [Re: Ryan Anderson] #18891
08/22/21 11:27 AM
08/22/21 11:27 AM
Falmouth, MA
Falmouth, MA
It has a paddle wheel for water speed so had to be thru-hull mounted. The job ended up being pretty straight forward.
0 registered members (), 26 guests, and 1 spider.
First cruise
Pulling J30 Mast balance point
by Russ Atkinson. 10/15/21 10:31 AM
#1 Doyle Genoa
by Ryan Anderson. 10/12/21 08:25 PM
Yellow substance leaking from keel
by Rhapsody #348. 10/11/21 07:38 AM
Harken windward sheeting traveler
by pez. 10/08/21 11:36 AM
by Georges. 10/04/21 07:13 PM
North Mains
by Bob Rutsch. 09/28/21 10:28 AM
1979 J/30 cruiser for sale, $8k Seattle area
by GreyJay. 09/24/21 02:09 PM
1979 J/30 For Sale - San Diego, CA
by Orcamike. 09/24/21 12:28 AM
replacing bilge pump
by Gary. 09/20/21 11:51 AM
Spreaders
by Gary Krogman. 09/14/21 05:52 AM
