977,822 Dacron Main
163,185 Ananda's Refit
replacing bilge pump #18903
09/19/21 09:46 PM
09/19/21 09:46 PM
Friday Harbor, WA
G
Gary Offline OP
Gary  Offline OP
G
Friday Harbor, WA
Somebody was too exuberant pumping the bilge, and the pump finally broke. Any one had any luck with replacements the fit the cockpit opening?
Thanks, Gary
Re: replacing bilge pump [Re: Gary] #18904
09/20/21 08:58 AM
09/20/21 08:58 AM
Grand Haven, MI
Brian Kelly Offline
Brian Kelly  Offline
Grand Haven, MI
We rebuilt ours last winter. Ours is a Henderson MKV (MK5) Underdeck (Henderson Mark 5). I wrote down BP0535 as a part number and Service Kit AK8050 as the rebuild kit. Henderson is now Whale Pump whalepumps.com I had to look around online a little to fine the "vertical" mount version that matched what we have.
Good Luck,
Brian
Re: replacing bilge pump [Re: Brian Kelly] #18905
09/20/21 11:51 AM
09/20/21 11:51 AM
Friday Harbor, WA
G
Gary Offline OP
Gary  Offline OP
G
Friday Harbor, WA
Brian: thanks for the info. From what I've seen online, the Whale Gusher Urchin pump is pretty close to the original. Time to place an order.
Gary
