January
Dan Fallon, Fuzzystx, martinrobb7, Fu1e, Valhalla33242
974 Registered Users
902,934 Dacron Main
143,488 Ananda's Refit
Topics3,845
Posts18,672
Members975
Most Online223
Dec 17th, 2019
Yellow substance leaking from keel #18915
10/11/21 06:09 AM
10/11/21 06:09 AM
Falmouth, MA
Ryan Anderson Offline OP
Falmouth, MA
A week after being hauled out I noticed a yellow substance coming out of the keel. It was kind of sticky, and then a week later it dried and now resembles dried mud. The area around the substance has a very thin soft layer, I can push it in like a piece of bubbled out paper. Underneath seems solid. There is a slight discoloration of the paint surrounding the area. Any idea what this is? Is a repair needed?
IMG_6973.jpg [26.61 KBytes] - (62 downloads)
IMG_6974.jpg [42.33 KBytes] - (59 downloads)
IMG_6975.jpg [17.83 KBytes] - (58 downloads)
IMG_6976.jpg [43.05 KBytes] - (58 downloads)
Re: Yellow substance leaking from keel [Re: Ryan Anderson] #18916
10/11/21 06:38 AM
10/11/21 06:38 AM
You are seeing the result of water that has penetrated the barrier coat / fairing.
  • Use an orbital sander and sand the area down to reach the lead.
  • Make sure all the areas on the edge are well bonded to the lead
  • Feather the edges about 2 inches so there is no bottom paint, just the barrier coat and fairing
  • Score the lead using a stiff wire brush
  • Mask around the area
  • mix unthickened neat epoxy and use the wire brush to work it in the scored lead
  • tape release cloth over the area, squeegee smooth and let cure
  • peel release cloth when cured and wash with plain water to remove any amine blush
  • dry and light sand with 80 grit paper to rough up cured epoxy - hand sand so you don't burn through, then wipe clean with acetone
  • apply Interprotect 2000e barrier coat - one coat and let cure
  • If there are any low spots fair with epoxy thickened with microlight fairing compound and let cure
  • sand with 80 grit and wipe clean with acetone
  • apply 3 layers Interprotect 2000e - you can follow the timing using the thumbprint test for recoat.
  • apply bottom paint within the time limit for thumbprint test, or later which requires light sanding.
ps - I entered you in the fleet database. You can access your record when logged in to the forum by clicking on your user name, then click View Profile. Click Class Database Link next to J/30 Profile. You can update information there.
Last edited by Rhapsody #348; 10/11/21 07:35 AM. Reason: added ps about fleet database
0 registered members (), 37 guests, and 0 spiders.
First cruise
J30 for parts in BC (Not mine)
by neumannaudio. 01/14/22 03:58 PM
Stern Perch Seats - SOLD
by Michael L. 12/07/21 03:06 PM
Looking for 170
by Chris Edwards. 11/26/21 01:04 PM
Boom Selection
by Rhapsody #348. 11/11/21 01:48 PM
by Ryan Anderson. 11/11/21 12:50 PM
Is sail no. 401 around? Used to be called White Dolphin
by whitedolphin. 11/08/21 12:12 PM
Heater location / Cabin pan profile?
by Pabs. 10/26/21 04:09 PM
Parts available
by Rob Larkin. 10/26/21 07:12 AM
