May
Sean0002, Windseeker, RobertKirrane, Stella 1, CharlieH
980 Registered Users
910,662 Dacron Main
146,015 Ananda's Refit
Topics3,871
Posts18,732
Members981
Most Online223
Dec 17th, 2019
Powder coat Boom #18947
01/27/22 07:08 PM
01/27/22 07:08 PM
West Michigan
Ricochet Offline OP
Ricochet  Offline OP
West Michigan
Our boom, original to the boat, is looking pretty shabby. Is it OK to pull everything off and sandblast and powder coat the boom tube? Any disadvantages to powder coating over just painting?
Jeremy Cox
Ricochet Hull #89
Re: Powder coat Boom [Re: Ricochet] #18948
01/29/22 12:46 AM
01/29/22 12:46 AM
Powder coat is actually the preferred finish that new aluminum spars are made with. It is more durable than painting. Properly preparing by sand blasting as you state is the right way to go. When I had Rhapsody I didn't have access to powder coat resources so sanded and painted the boom.
Re: Powder coat Boom [Re: Ricochet] #18950
01/30/22 02:49 PM
01/30/22 02:49 PM
West Michigan
Ricochet Offline OP
Ricochet  Offline OP
West Michigan
Thanks, that's what I thought. Found a guy local to me that did my winter rims for my car fairly cheap and they turned out great. He has a pretty large oven, so I do think it would fit.
I do need to pull the out haul out anyway and rework it. So this will be a good time to pull everything and get it done right. Thinking new decals on both sides too.
Jeremy Cox
Ricochet Hull #89
0 registered members (), 42 guests, and 2 spiders.
First cruise
Freeboard & Lifeline Height
by watchoverya. 05/22/22 11:59 AM
Looking for main sail
by Sean0002. 05/18/22 07:12 AM
Placement of bow cleat
by Georges. 05/14/22 11:20 AM
Core Thickness
by Georges. 05/14/22 11:09 AM
Cons that can be Corrected
by Georges. 05/14/22 10:46 AM
Secondary Bearing
by Kellen. 05/12/22 05:58 PM
Parts available
by lumpy. 05/04/22 03:00 PM
Need pintles and gudgeons
by lumpy. 04/26/22 06:13 PM
