Re: PHRF Rating?
#1892
05/03/06 06:04 PM
05/03/06 06:04 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
I am re-submitting for a rating with the same configuration so it will be interesting to see what the difference is when I get mine.
Have you noticed if the boat does not point as well with the 135 due to the wide sheeting angles?
David #397
Re: PHRF Rating?
#1893
05/12/06 12:37 AM
05/12/06 12:37 AM
Posts: 4 Oakville, Ontario, Canada
j30-oys
I am new to the forum. I just found out that my rating for this season is going to be 135. We have a class # 1 and a class lenght pole. Does this number make sense?
Eli J30 ~ 477
Re: PHRF Rating?
#1895
05/12/06 08:07 AM
05/12/06 08:07 AM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
Which PHRF area are you in? PHRF-NB has the following J/30 ODR rating: 137 Spin, 154 Non-Spin
Re: PHRF Rating?
#1896
05/13/06 01:08 AM
05/13/06 01:08 AM
j30-oys
PHRF-LO, Yes other J30's in this region have similar ratings. I think that there are now less than 10 racing on Lake Ontario.
Eli J30 ~ 477
guests, and 1
spider. |
