Can someone confirm the charge lamp is suppose to be lit if everything is working correctly when the engine is running? The manuals have some conflicting info regarding if the normal state should be on or off. I have the Yanmar 2GM, instrument panel type B.
Is there an easy way to check that the alternator is working?
