978,183 Dacron Main
163,283 Ananda's Refit
Cut back V-Berth bulkhead? #19047
07/30/22 06:26 PM
07/30/22 06:26 PM
Seward, AK
P
Patrick Stinson Offline OP
P
Seward, AK
Does anyone know if the starboard bulkhead at the aft end of the v-berth in front of the toilet can be cut back? I'm wondering if it is structural. Doesn't seem so since it's so thin. But this would make getting into the v-berth, changing clothes, etc SO much easier.
Cheers,
-Patrick
Re: Cut back V-Berth bulkhead? [Re: Patrick Stinson] #19049
07/31/22 09:34 PM
07/31/22 09:34 PM
The chain plates are attached to that bulkhead and it provides stiffness to the hull shape to prevent deformation. Yes it is structural.
Re: Cut back V-Berth bulkhead? [Re: Patrick Stinson] #19063
08/13/22 01:54 PM
08/13/22 01:54 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
Bill,
I believe the OP is talking about the bulkhead at the forward end of the head. No chain plates attached to that bulkhead.
Rob
Re: Cut back V-Berth bulkhead? [Re: Rob Van Name] #19066
08/13/22 02:44 PM
08/13/22 02:44 PM
Seward, AK
P
P
Seward, AK
That’s right.
Now that I got the idea I’d find it he’d to imagine any cruiser not doing it. Still haven’t cut it out though.
Originally Posted by Rob Van Name
Bill,
Rob
Re: Cut back V-Berth bulkhead? [Re: Patrick Stinson] #19274
08/05/23 12:24 PM
08/05/23 12:24 PM
Seward, AK
P
P
Seward, AK
Finally did it. The forepeak is SO much nicer now. Much easier to get into. I just need to sand and varnish the edge. Cut was made with a multitool from aft going foreward so as not to damage the locker.
I am trying to figure out why everyone doesn't do this.
Photos attached
721.jpg [58.7 KBytes] - (51 downloads)
Re: Cut back V-Berth bulkhead? [Re: Patrick Stinson] #19279
08/15/23 08:31 PM
08/15/23 08:31 PM
Christiansted, St. Croix
Fuzzystx Offline
Fuzzystx  Offline
I have removed everything from the v berth on mine. its wide open up there now.
Re: Cut back V-Berth bulkhead? [Re: Patrick Stinson] #19282
08/23/23 11:51 AM
08/23/23 11:51 AM
Annapolis, MD US
LChristy Offline
J/30 Class Measurer
LChristy  Offline
J/30 Class Measurer
Annapolis, MD US
Under the J30 rules you may not remove that bulkhead. In addition, you may not remove the door to the head!!
From J30 Rules
1.2 It is the intent of the J/30 Class Association and J/Boats, Inc. to maintain the one-design performance characteristics of the J/30 To this end, any substantive change that alters the weight, distribution of weight, shape or performance of the hull, rig or underwater appendages shall be submitted by J/Boats, Inc. to the J/30 Board of Governors for approval prior to implementation.
1.3 Except where variations are specifically permitted, yachts of this Class shall be alike in hull, deck and keel form, construction, weight and weight distribution, shape of rudder, sail plan and equipment. All boats shall be built in accordance with the plans, specifications and these class rules. No alternatives or modifications are permitted unless explicitly stated in these rules or on the official plans or building specifications.
Larry Christy
J30 Class Measurer
Re: Cut back V-Berth bulkhead? [Re: LChristy] #19283
08/23/23 12:00 PM
08/23/23 12:00 PM
Seward, AK
P
P
Seward, AK
Are we talking about the same bulkhead? In fact what I'm talking about is not even a bulkhead but a faux wall. The piece in question weights about as much as the bosuns chair, cooking utensils, or any other items that could be anywhere on or off the boat. I don't see a match with any piece anywhere in the class rules description.
Plus, we are in Seward, Alaska which is literally the US port farthest from any one design fleet. And this makes a huge difference in the usability of the boat. So I don't think this is the same issue.
0 registered members (), 45 guests, and 1 spider.
