Replacing original 2GM with a 2YM15
#19052
08/06/22 09:33 AM
08/06/22 09:33 AM
Posts: 88 Belmont, MA
Georges
Belmont, MA
I am considering having my old 2GM (from 1984) - still loyal, but rusty, smoky, a bit oily - replaced by a 2YM15 on FootLoose a 1984 model. By a mechanics, not me. Anyone had done this already? Is it a drop-in replacement - mostly? (I have the dimension diagram for the 2YM15 - but could not yet put my hand on the 2GM ones...so will measure by hand...) Does it fit the original Kanzaki transmission? Any notion of the price?
Thanks!
Re: Replacing original 2GM with a 2YM15
[Re: Georges]
#19069
08/15/22 12:50 PM
08/15/22 12:50 PM
Georges
Belmont, MA
Thanks so much Rob... super useful. Note - the J/30 84' variant dot not have this bulkhead. The engine as a whole is less accessible, but then, it has some pros :-)
[Re: Georges]
#19071
08/15/22 01:59 PM
08/15/22 01:59 PM
Georges
Belmont, MA
Thanks Rob, With you on the accessibility aspect...although it only bites me when changing the oil - I need a long snake-funnel to fill it up...
Having photos of the installation on the 84+ vintage will surely make me less anxious - but then - not a showstopper for me nor anything urgent: your pics already gave me confidence I needed...
Thanks again.
[Re: Georges]
#19073
08/15/22 02:17 PM
08/15/22 02:17 PM
Georges
Belmont, MA
Thanks Rob, yes I noticed... I might actually have to move my raw water strainer... will see. I do not expect everything to fit right in :-) But if the engine fits, the fixation fits, and the overall engine+transmission fits my old 2GM propeller shaft length and alignment - I will be happy :-)
[Re: Georges]
#19079
08/18/22 04:38 PM
08/18/22 04:38 PM
Georges
Belmont, MA
Pictures and possibly the brand and model of the transmission ? at least if not the Kanzaki KMP2-1 shown in the 2YM15 Yanmar diagram with its dimension... Thanks again.
[Re: Georges]
#19088
08/21/22 10:45 AM
08/21/22 10:45 AM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
According to the Yanmar specs the Kanzaki KM2P-1 transmission fits both the 2YM and 2GM series and for the J/30 uses 2.62:1 gear ratio. When I had Rhapsody the 2GM raw water cooled engine had the oil filter on the port side. I've seen 2YM installations where a removable panel was installed on stbd side to easily access the oil filter. My J/109 with 3YM30 has a removable panel in the head just for that purpose. It's probably easy on the J/30 to use a scroll saw and make a cutout on the stbd side, then screw in a frame on the back to hold a piece of wood that would be removable for the oil change.
47
guests, and 1
spider. |
