Re: Bladder Type Holding Tank
[Re: Steve Buzbee]
#7091
03/10/09 06:37 PM
03/10/09 06:37 PM
Posts: 2,669 Portsmouth, RI
Rhapsody #348
I think your dimension estimates are on the large side, but don't have better data to support that without actual measurements. I do know there is no way the holding tank is larger than the potable water tank, which on Rhapsody is 18 Gallons. Other Data to support the Tank Capacity: Hull #371 - 14 Gallon Holding Tank Hull #512 - 10 Gallon Holding Tank Hull #80 - 12 Gallon Holding Tank Hull #444 - 10 Gallon Holding Tank I'll throw in an extra gallon on the largest shown just for you and call it an even 15....
[Re: Rhapsody #348]
#7097
03/11/09 07:03 PM
03/11/09 07:03 PM
Posts: 649 Marblehead, MA
dbows
Marblehead, MA
I think mine is 12 - 15 gallons. I know 8-10 flushes is about max before I like to off load when I am cruising.
Anyway I was really just wondering if anyone had done this - I think I will just replace with what I have.
[Re: Steve Buzbee]
#7104
03/11/09 08:50 PM
03/11/09 08:50 PM
Rhapsody #348
Steve - there very well could be a difference in model years and explain why our perceptions on tank size are so different. I've attached a picture of the space between the aft end of the holding tank and the bulkhead on the aft end of the space. The tank occupies about the forward third of that space and flits flush against the bulkhead by the anchor locker. You can estimate dimensions by scaling from the size of the hose (1-3/4" OD) and the 8-1/2" x 11" paper chart taped on the tank. You also mention two water tanks. Hull 348 only has a single 18 gallon polypropylene water tank under the port settee. If Rod Johnstone calls in for the BOG meeting on 24 March, I'll ask him what he knows about the tank sizes. Sanitary Piping Diagram & Valve Lineup
[Re: Steve Buzbee]
#7115
03/12/09 12:30 PM
03/12/09 12:30 PM
dbows
Marblehead, MA
The picture is exactly like mine. Except you could not eat off it as you could Bill's.
Rules Interpretation: Bladder Type Holding Tank
[Re: dbows]
#11141
02/23/11 02:28 PM
02/23/11 02:28 PM
Posts: 186 Barrington, RI
cstoddard
Barrington, RI
following is my "Rules Interpretation" on this issue
A holding tank is required with a capacity equal or greater to the original equipment (about 14 gallons) The tank must be located in the same location as the original tank. Bladder tanks are an acceptable alternative. Installation for discharge must be in accordance with the current federal and state laws
Charlie Stoddard Falcon #229
39
guests, and 1
spider. |
