Tuff Luff extrusion size
#1911
11/28/05 11:27 AM
11/28/05 11:27 AM
Posts: 15 Alexandria, VA USA
Tom Watson
Alexandria, VA USA
I'm wondering what size Tuff Luff folks are using. We replaced our current 1205 extrusion for #5 luff tape (4mm) at the begining of this past season. I've found that a number of our (older) jibs don't fit in it very well. I examined a number of other local boats they were using the slightly larger 1706 extrusion for #6 luff tape (5mm). I'd like to be more compatable with other boats, I was wondering which extrusion/luff tape set up you were using?
tom watson
44
guests, and 14
