atowns, Jporter, jaguarshark, Scot Benton, Bill492
1012 Registered Users
967,831 Dacron Main
160,384 Ananda's Refit
Topics3,972
Posts19,039
Members1,012
Most Online223
Dec 17th, 2019
Stripped Jib Halyard #19271
08/02/23 03:58 PM
08/02/23 03:58 PM
Fort Worth, TX
watchoverya Offline OP
Fort Worth, TX
For those who do such a thing, how long do you strip the cover off your jib halyards?
Re: Stripped Jib Halyard [Re: watchoverya] #19272
08/05/23 07:04 AM
08/05/23 07:04 AM
  • Mark the cover where you want the strip to start
  • Tie a slip knot about a foot up from the mark away from the stripped end
  • Milk the cover over the core to expose the core working towards the slip knot
  • Pull the cover back down with a loose fit (don't milk it tight as you want to be able to slide the core out)
  • Use a fid at the mark and separate cover strands to pull the core out, starting with a small loop and pulling the loop so the core comes from the end that was loosened
  • Remove the slip knot and milk the cover down over the core, then insert a needle to lock the cover to the core
  • Lock stitch the cover and core a couple inches above where the core and cover separate
  • Mark the core about 2.5 feet away from the separation point
  • Cut the cover about 2 feet from the separation point
  • Use a fid to insert the cover in the center of the exposed core starting a couple strands past where the core and cover separate, then have this exit where the core was marked
  • Pull the cover tightly to expose as much as possible out of the exit point from the core
  • Separate the cover strand and taper the end of the exposed cover
  • Milk the core over the exposed cover to bury the cover in the center
  • Lock stitch along where the cover is buried
  • Whip the transition point area and lock stich the whipping
Re: Stripped Jib Halyard [Re: Rhapsody #348] #19273
08/05/23 08:21 AM
08/05/23 08:21 AM
Fort Worth, TX
Fort Worth, TX
Thanks, Bill. I've got the method in hand, having stripped my spin sheets. The question is how much cover to take off the jib halyard.
Re: Stripped Jib Halyard [Re: watchoverya] #19275
08/07/23 04:45 PM
08/07/23 04:45 PM
Maryland, USA
Bob Rutsch Offline
Bob Rutsch  Offline
Maryland, USA
Jib halyard 5/16" Endura Braid 93' of raw line
5" reeving eye splice at tail, uses up about 10" of just the cover
Crossover 24' from shackle, using luggage tag, brummel lock splice on core for shackle
Final length after all splicing is done is about 87'
Re: Stripped Jib Halyard [Re: watchoverya] #19276
08/07/23 04:49 PM
08/07/23 04:49 PM
Fort Worth, TX
Fort Worth, TX
Thank you. I may have uncovered a bit much, like 28' but it will work.
Re: Stripped Jib Halyard [Re: watchoverya] #19277
08/08/23 10:11 AM
08/08/23 10:11 AM
Maryland, USA
Bob Rutsch Offline
Bob Rutsch  Offline
Maryland, USA
When it begins to wear near the sheave you can cut a couple feet off the stripped end and splice a new eye. That also moves the location of clutch wear. The stripped Dyneema gets 'hairy' with thin strands standing out along the line when it is due for replacement. Then all you have to worry about is ripping a section of stainless out of your 40 year old Gibb Shackle in 25 knots of breeze.
2023-0923 J30 jib shackel broken bail-1.jpg [19.46 KBytes] - (140 downloads)
Re: Stripped Jib Halyard [Re: watchoverya] #19291
09/24/23 06:24 PM
09/24/23 06:24 PM
Queens, NY
B Davis Offline
B Davis  Offline
Queens, NY
26’ 5” from halyard shackle or stopper ball. 26’ works just as well. Your mast person won’t have to be handling any dyneema at the end of the hoist.
0 registered members (), 29 guests, and 1 spider.
First cruise
Mast
by Fuzzystx. 11/28/23 11:58 AM
PRO Training
by watchoverya. 11/13/23 04:51 PM
Data Marine instruments free to a good home
by Navy Dan. 10/18/23 09:12 AM
Wanted, Gently Used: Main, #1, #2.
by mattjenPDX71. 10/14/23 11:34 AM
Hatch slide tracks
by Rhapsody #348. 10/10/23 01:00 PM
#2 Dacron Jib
by Brent. 10/07/23 10:47 AM
Caribbean
by Fuzzystx. 10/04/23 01:06 PM
by B Davis. 09/24/23 06:24 PM
