Topics3,972
Posts19,039
Members1,012
Most Online223 Dec 17th, 2019
Stripped Jib Halyard
#19271
08/02/23 03:58 PM
08/02/23 03:58 PM
Posts: 21 Fort Worth, TX
watchoverya
Fort Worth, TX
For those who do such a thing, how long do you strip the cover off your jib halyards?
Re: Stripped Jib Halyard
[Re: watchoverya]
#19272
08/05/23 07:04 AM
08/05/23 07:04 AM
Posts: 2,667 Portsmouth, RI
Rhapsody #348
- Mark the cover where you want the strip to start
- Tie a slip knot about a foot up from the mark away from the stripped end
- Milk the cover over the core to expose the core working towards the slip knot
- Pull the cover back down with a loose fit (don't milk it tight as you want to be able to slide the core out)
- Use a fid at the mark and separate cover strands to pull the core out, starting with a small loop and pulling the loop so the core comes from the end that was loosened
- Remove the slip knot and milk the cover down over the core, then insert a needle to lock the cover to the core
- Lock stitch the cover and core a couple inches above where the core and cover separate
- Mark the core about 2.5 feet away from the separation point
- Cut the cover about 2 feet from the separation point
- Use a fid to insert the cover in the center of the exposed core starting a couple strands past where the core and cover separate, then have this exit where the core was marked
- Pull the cover tightly to expose as much as possible out of the exit point from the core
- Separate the cover strand and taper the end of the exposed cover
- Milk the core over the exposed cover to bury the cover in the center
- Lock stitch along where the cover is buried
- Whip the transition point area and lock stich the whipping
guests, and 1
spider. |
Mast
by Fuzzystx. 11/28/23 11:58 AM
