June
knothead, Robert Lama, SahilN, jannickz, LLBoat
1022 Registered Users
983,626 Dacron Main
164,693 Ananda's Refit
Topics3,986
Posts19,083
Members1,023
Need Spreader #19350
05/03/24 11:04 PM
05/03/24 11:04 PM
Toronto, ON
E
Eric Whan Offline OP
E
Toronto, ON
My starboard spreader failed while stepping the mast and pulling the shroud down through the wired spreader tip. I put too much load on it -- shame. The extrusion cracked longitudinally at the mouth of the spreader, where it mounts onto the SS bracket. But better it fail at the crane dock than while underway, of course.
Might anyone have one, or a set, of spreaders they would like to sell? I am in Toronto, but suspect this search might need a wide geographic net. No sailing my boat until this is fixed.
Eric Whan
220
Re: Need Spreader [Re: Eric Whan] #19352
05/16/24 02:23 PM
05/16/24 02:23 PM
ON
Chris Edwards Offline
ON
I got a set in Windsor, they are my spares. How's 250 CAD and I can get them in the mail tomorrow.
Re: Need Spreader [Re: Chris Edwards] #19353
05/17/24 10:16 AM
05/17/24 10:16 AM
Toronto, ON
E
E
Toronto, ON
Thank-you Chris! I was able to get a weld repair and reinforcement done through the good folks at The Rigging Shoppe in Toronto. I appreciate your offer and knowing that you have a boat in Windsor.
0 registered members (), 25 guests, and 0 spiders.
by Sunrise. 06/20/24 03:39 PM
by Georges. 06/05/24 06:15 PM
Replacement Shaft Strut / Galvanic Corrosion
by ivanjrod. 06/03/24 04:39 PM
Cut Engine Cover in Half
by Patrick Stinson. 05/28/24 10:56 PM
Need Spreader
by Eric Whan. 05/17/24 10:16 AM
by B Davis. 04/29/24 12:41 PM
