29 30 31
juan luna, PestoJ30, Joe Knight, knothead, Robert Lama
1025 Registered Users
986,745 Dacron Main
165,480 Ananda's Refit
Topics3,987
Posts19,087
Members1,025
Replacement Shaft Strut / Galvanic Corrosion #19199
05/16/23 06:43 PM
05/16/23 06:43 PM
Sudbury, Massachusetts, USA
andrewware Offline OP
Has anyone seen a shaft strut with this appearance? Looks to be galvanic corrosion, I plan to grind it for a better look, check the inside, and check bonding (I've had the boat 15 years and it appears to be bonded but never checked where this meets the hull from the inside). Any idea where to purchase a replacement?
IMG_2830.jpg [54.25 KBytes] - (64 downloads)
IMG_2831.jpg [48.3 KBytes] - (50 downloads)
Re: Replacement Shaft Strut / Galvanic Corrosion [Re: andrewware] #19233
06/14/23 08:04 PM
06/14/23 08:04 PM
Melbourne, FL, USA
Rob Van Name Offline
Melbourne, FL, USA
I have heard the shaft strut is no longer available unless you can find one off of a boat being parted out.
Re: Replacement Shaft Strut / Galvanic Corrosion [Re: andrewware] #19317
12/20/23 04:50 PM
12/20/23 04:50 PM
Los Angeles
J
John DeGolyer Offline
J
Los Angeles
I have a replacement shaft, folding prop and strut from my J-30
John John@sailsolar.com 310-749-6996
Re: Replacement Shaft Strut / Galvanic Corrosion [Re: andrewware] #19355
06/03/24 04:39 PM
06/03/24 04:39 PM
Puerto Rico
ivanjrod Offline
ivanjrod  Offline
Puerto Rico
Hi,
Does anybody still have a strut? Please let me know. Text to 787-667-7778 or sailsanjuanbay@gmail.com.
Sail San Juan Bay
Authentic Sailing by the bay of San Juan Puerto Rico
0 registered members (), 19 guests, and 1 spider.
Raising the main; slugs get stuck
by Navy Dan. 07/17/24 06:50 PM
Main Sail Slugs
by juan luna. 07/09/24 07:34 PM
Sail slugs/slides on the mainsail
by juan luna. 07/09/24 06:15 PM
by Sunrise. 06/20/24 03:39 PM
by Georges. 06/05/24 06:15 PM
by ivanjrod. 06/03/24 04:39 PM
Cut Engine Cover in Half
by Patrick Stinson. 05/28/24 10:56 PM
Need Spreader
by Eric Whan. 05/17/24 10:16 AM
by B Davis. 04/29/24 12:41 PM
